Truck tuba inside...?
himhimself
Just pondering sub placement in my great room and wondering how truck tubas would do inside the house. At about 6 inches, I realized I could build a pair and slide one under each sofa for a true invisible set up. Maybe it needs the cabin gain of a vehicle to sound good. I loaned mine out TT some time ago. I'll get it back and try it but thought I'd ask if anyone had experience or opinion.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
Re: Truck tuba inside...?
It does need cabin gain. Small TTLS is as small as I'd go.
himhimself
Thanks, Bill. Figured as much but thought I'd ask. Will figure out the placement challenge -need the the best bass!
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
Okay to try what you already have. But, I wouldn't recommend it if you were looking to build something for that purpose.
I've used my 2x8 8½" TrT in my 12x30 storage unit and it sounded really good. It's not super loud and I had to add a ton of bottom end EQ. But, I did have a neighbor about 5 doors down and on the back side of the building from where my unit is, come over and and in a really annoyed winey bitch voice asked if I would turn it down. If you have sufficient DSP, give it a go and see if it meets your expectations. Won't hurt anything to try it. I was powering it with an old Behringer iNuke 1000DSP I had laying around, which seems to put out about 35V per channel, IIRC.
- Scott Brochu
I don't think there is a town or community that doesn't have one of those.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
I like the idea, but we all know it's not the right tool for the job. I'm using my AT as my ht sub currently and couldn't be happier. Can't hurt anything by trying it out. I think you're just trying to convince yourself to build more TT's. You should totally do that.
You guys are both cracking me up today. I needed that. Thanks a bunch.Bill Fitzmaurice wrote: ↑Thu May 30, 2024 9:21 pmI had a problem with that too. She's now my ex-wife.![]()
