Hi!
Does anyone happen to know of a good alternative for the BMS H4552ND?
It was at one point a recommended compression driver for the lowest crossover (1kHz) in the DR280 plans.
BMS H4552ND Alternative
Funky Town BRC Sound System
6 x Omni-Top (2 x 3012HO)
12 x Tuba 60s
2 x Crown XLS5000
1 x Crown XTi4002
dBX Drive Rack PA2+
12 x Tuba 60s
2 x Crown XLS5000
1 x Crown XTi4002
dBX Drive Rack PA2+
Re: BMS H4552ND Alternative
If your plans are old, you might consider contacting Bill for an update. New plans suggest Eminence F151M-8 for the lower 1.2 kHz (not 1.4kHz) crossover point.
Get the updated plans for the T60's too. Important modifications to the design have been made, allowing a wide range of driver choices instead of just the LAB's.
My plans are old, so I gotta' ask........ is the 1.4k you mentioned a typo or did the crossover change with the F151M? It's always been 1.2k.
Good catch, Bruce. 1.2kHz is correct in the new plans too. I wish I could claim fat fingers, but that mistake occurred upstairs.Bruce Weldy wrote: ↑Fri Mar 29, 2024 8:38 amMy plans are old, so I gotta' ask........ is the 1.4k you mentioned a typo or did the crossover change with the F151M? It's always been 1.2k.
No problem....just making sure.Seth wrote: ↑Fri Mar 29, 2024 2:10 pmGood catch, Bruce. 1.2kHz is correct in the new plans too. I wish I could claim fat fingers, but that mistake occurred upstairs.Bruce Weldy wrote: ↑Fri Mar 29, 2024 8:38 amMy plans are old, so I gotta' ask........ is the 1.4k you mentioned a typo or did the crossover change with the F151M? It's always been 1.2k.
