Speakercable in T48
Evarist2
Speakercable in T48
#1 Post by Evarist2 »
Hello everyone, as I am building my first T48 this week I was reading the plans. In sketchup, I saw that the speakon jacks get installed on the bottom in the sketchup plans. But how do I get the cables to the driver in the best way possible? So that the cables aren't seen, and doesn't impact performance of the speaker?
I was just wondering how others did it, so I can do it as best as possible!
Thanks in advance, Evarist.
Evarist2
Re: Speakercable in T48
#2 Post by Evarist2 »
Also, birch plywood seems to be sold out everywhere. However the dealer said maple has the same characteristics. Is maple plywood good aswell? From some reading, it should do the job aswell as its similar to birch.
#3 Post by Bruce Weldy »
Evarist2 wrote: Wed Aug 02, 2023 4:40 am Also, birch plywood seems to be sold out everywhere. However the dealer said maple has the same characteristics. Is maple plywood good aswell? From some reading, it should do the job aswell as its similar to birch.
No. You don't want a thin veneer ply. Baltic Birch has equal plies - Birch doesn't. Nor does oak, maple, etc. It's about the plies, not the species.
#4 Post by Bill Fitzmaurice »
'Everywhere' depends on where you live. You should add your location to your profile.
Evarist2
#5 Post by Evarist2 »
Bill Fitzmaurice wrote: Wed Aug 02, 2023 9:34 am
Sorry, I'll add my location. I am from Belgium, West-Flanders.
Evarist2
#6 Post by Evarist2 »
From what I know, the maple plywood has popler in them (in the core) with the outer veneers being maple. Is that a big issue?
#7 Post by Bill Fitzmaurice »
Evarist2
#8 Post by Evarist2 »
Bill Fitzmaurice wrote: Wed Aug 02, 2023 10:15 am You don't want a thin veneer ply.
How do I make sure it isn't a thin veneer ply? How can I tell?
#9 Post by Tom Smit »
If you can't get BB, then get a plywood that has a minimum of 5 even plies (as per the plans). BB is the premium plywood to get but may be difficult to acquire.
As for the speaker wire, I found the answer on page 20 (of my plans which may be old).
Read through your plans many times, and try to understand each stage. Then, when it is time to build, you will likely have a good recollection of what is needed to be done.
Evarist2
#10 Post by Evarist2 »
Tom Smit wrote: Wed Aug 02, 2023 9:44 pm If you can't get BB, then get a plywood that has a minimum of 5 even plies (as per the plans). BB is the premium plywood to get but may be difficult to acquire.
Thanks for your response! I'll be reading the plans again thoroughly.
#11 Post by Bruce Weldy »
Evarist2 wrote: Wed Aug 02, 2023 10:29 am
Thin veneer is on cabinet grade ply. All you have to do is look at the edge of the ply. The thin veneer is very obvious. Baltic birch will nine equal plies in a half inch.
This is 6 pieces all together, but you can see the 9 plies on each panel....click on the pic to make it bigger.
Evarist2
#12 Post by Evarist2 »
Bruce Weldy wrote: Thu Aug 03, 2023 7:13 am
Alright, thanks a lot for the picture! It clarifies everything. Tomorrow, we will go pick up the wood, I hope it is going to be good. Else I will have to wait 2 - 3 months for it to get back in stock.
UPDATE:
Forwaded the picture to my cousin, he says all the ply he orders looks like that, no thin veneer on the outsides.
#13 Post by Bruce Weldy »
Evarist2 wrote: Thu Aug 03, 2023 7:51 am
UPDATE:
It can be called Baltic birch, Finnish birch, or Russian birch. You are a lot closer to where it's made than we are....hopefully, it's cheaper.
Evarist2
#14 Post by Evarist2 »
Bruce Weldy wrote: Thu Aug 03, 2023 8:53 am It can be called Baltic birch, Finnish birch, or Russian birch. You are a lot closer to where it's made than we are....hopefully, it's cheaper.
Well it isn't much cheaper I think, don't know what the prices are over there, but for three plates (I have to use 2.5, for one T48) it will cost me between €320 and €350. It is definitely not cheap...
#15 Post by Bruce Weldy »
Evarist2 wrote: Thu Aug 03, 2023 9:37 am
Yikes! It's cheaper than that here.
