there is a mistake in the tuba 60 plans
holzboss
#1 Post by holzboss »
on thr page 4 on the diagram i have two same parameters 9 3/4 is there two times and there should be another number because it is not straight on the image
Re: there is a mistake in the tuba 60 plans
There is no mistake. The measurements were taken directly on the sketchup model. Measure your own sketchup and you'll see.
#3 Post by Seth »
I assume you're talking about the lower right corner of Layout Diagram 1 on page 4 and Layout Diagram 2 on page 5...
Here's how those two 9¾" dimensions coincide with each other, each is indicated with a red circle
