need help with cutting the angles
holzboss
#1 Post by holzboss »
How do i cut the angles in plywood for the tuba 60????
Some tricks or tips?
Re: need help with cutting the angles
Follow the plans. For instance, 'Cut and install panel 2. If you don’t have a saw capable of cutting at 54 degrees cut that end at 45 degrees, and sand the excess off'.
#3 Post by Seth »
holzboss wrote: Fri Oct 16, 2020 8:37 am How do i cut the angles in plywood for the tuba 60????
Not knowing how familiar you are with the tools them selves, just thought I'd mention that a circular saw has an adjustable foot to make the cuts Bill mentioned above.
If you're very new to using these tools, watch a bunch of YouTubes to learn about features, techniques, and most importantly... safety.
