How do i cut the angles in plywood for the tuba 60????
Some tricks or tips?
need help with cutting the angles
Re: need help with cutting the angles
Follow the plans. For instance, 'Cut and install panel 2. If you don’t have a saw capable of cutting at 54 degrees cut that end at 45 degrees, and sand the excess off'.
Not knowing how familiar you are with the tools them selves, just thought I'd mention that a circular saw has an adjustable foot to make the cuts Bill mentioned above.
If you're very new to using these tools, watch a bunch of YouTubes to learn about features, techniques, and most importantly... safety.
