Duratex – per, Square Foot Cost? - Hey Art Coates
Randall Dibble
#1 Post by Randall Dibble »
Hey Art.
What’s your guessimate of Duratex – per, Square Foot Cost using your techinque/method?
We are all immigrants and for most of us we haven't visited home recently, "Africa"!
Art Coates
#2 Post by Art Coates »
I used about half a gallon for 2 Omni 10's and 2/3 a gallon for 2 Tuba24. I'm thinking rolling isn't as cost effective as spraying in the long run.
#3 Post by Bill Fitzmaurice »
Art Coates wrote:I used about half a gallon for 2 Omni 10's and 2/3 a gallon for 2 Tuba24. I'm thinking rolling isn't as cost effective as spraying in the long run.
Rolling is a lot more cost effective, as chances are you'll use less of it. Spraying is so easy to do that you have a tendancy to just keep on adding more, whereas rolling is enough of a pain that after two coats the impulse is to pronounce 'good enough' and be done with it.
DAVID_L_PERRY
#4 Post by DAVID_L_PERRY »
Bill Fitzmaurices wrote:...........rolling is enough of a pain that after two coats the impulse is to pronounce 'good enough' and be done with it.
:D
Did mine over the weekend.....
2 Dr 290's and 2DR280's have been done with three coats using a roller from a 5kg tub of my UK duratex alternative (I also did a monitor using the same tub)
http://www.frappr.com/?a=viewphoto&id=1 ... myphotos=1
Finish is great, cost is pretty low (approx £16 for a 5kg tub). It becomes stronger over the first two weeks, and then its fairly scratch proof.
This is the DR290's I did last year:- http://www.frappr.com/?a=viewphoto&id=1 ... myphotos=1
Only need to leave about 1 hour in between coats.
Dave
fender3x
#5 Post by fender3x »
Looks good...and looks like Duratex. If that bucket is close to a gallon (US), then it's also a pretty good deal. About $20 cheaper than Duratex. Have we just found the one thing cheaper in the UK than the US? ;-)
fender3x
#6 Post by fender3x »
fender3x wrote:Looks good...and looks like Duratex. If that bucket is close to a gallon (US), then it's also a pretty good deal. About $20 cheaper than Duratex. Have we just found the one thing cheaper in the UK than the US? ;-)
Turns out it's cheaper than I thought... more like half the cost of Duratex since a "5 lbs tub" turns out to be 4.7 liters... or about 5 US quarts. They don't have a US distributor yet, but they are looking... If they can keep the price in that range it should be really competitive. I like my duratex, but that Aldcroft C33-27 looks pretty darned good--from the pics, I'd never have known it wasn't duratex. Also, I don't seem to be as frugal with mine as most of you guys. I am not much of a painter, so I seem to waste a lot... I'd feel better about that at half the cost ;-)
