On Board Amp
On Board Amp
This on board amp from Parts Express looks good, at a price that makes sense.
https://www.parts-express.com/dayton-au ... h--300-798
It could be mounted on just about any of our full range cabs with minor modifications. It has enough power to drive a pair of cabs, so it would be easy enough to install a 4 pole Speakon on the cab containing the amp and one on the extension speaker. Full DSP that includes crossover, EQ and limiting plus Bluetooth makes this a very attractive rig.
- BrentEvans
Re: On Board Amp
Not to mention it has two amps on board, making a biamped cab possible.
Re: On Board Amp
Thanks for the information!
2xDR300's
4xDual-30” Tuba 60’s
Simplex 21" Eminence NSW6021
1x20” THT
TLAH‘S
SLA Center-9 driver and Surrounds
SLA pros
TrT 10" Driver-10" Wide
Auto Tuba 10" Driver
2xDR300's
1x20” THT
TLAH‘S
SLA pros
Re: On Board Amp
That's the only way you'd want to use it. Until now nothing in this price range had all the features you want, especially the DSP capability.BrentEvans wrote: ↑Mon Oct 15, 2018 3:06 pm Not to mention it has two amps on board, making a biamped cab possible.
Re: On Board Amp
The first time I saw these amps I though the eq was a 5 preset aka rock pop vocal etc but upon farther investigation it is 5 band parametric with 5 saveable settings. these amps are needed in this industry. That’s a win for parts express and Dayton audio. I wish Dayton made more drivers that met these horn loaded demands.
Re: On Board Amp
Hello Member
I am building a pair of Jack 10 planing to use this on board amps , what kind of modifications do I need to mount this amp ? Any recommendation .
Thanks
Thanks
Re: On Board Amp
It would fit on the side, mounted upright towards the back of the cab.
Re: On Board Amp
threre are two pair of wire red and black blue and black how do I wire them . If i wire them parallel in to two speaker how do I do it ?Thanks
Re: On Board Amp
According to the instruction manual.
Re: On Board Amp
I red the manual from Dayton it did not say anything , I test out the red and black it working fine the blue and black to a second speaker only the tweeter sound . So I will give them a call tomorrow . BTW the amp fit just right on the side of the Jack
Thanks
Thanks
Re: On Board Amp
Near the bottom of page 4:
Outputs
● 1 XLR output
● 1 High Pass Output (Blue and Black Wire)
● 1 Low Pass Output (Red and Black Wire)
● 1 LED Output Header
Bottom of page 12:
"Notes
● The HIGH PASS output has a passive 1 kHz high pass filter. Even if you turn HPF off in this
menu, the signal is filtered out below 1 kHz. The LOW PASS output can output full-range. "
Re: On Board Amp
It's even at the bottom of the PE listing....
Specifications: • Amplifier type: Class D • Low frequency power rating (Red/Black wires): 600W RMS (4 ohms/1 kHz @ THD+N 1%) • High frequency power rating (Blue/Black wires): 200W RMS (4 ohms/8 kHz @ THD+N 0.1%) • Input sensitivity: LINE, 0 dBu; MIC, -24 dBu • Bluetooth version: 4.2 • Power: 120~240 VAC, 50/60 Hz, auto-sensing • Dimensions: 15" L x 6-5/16" W x 2-3/4" D • Cutout dimensions: 14" x 5-1/2" • Weight: 5.0 lbs.
Re: On Board Amp
Thanks
sorry for a dump question , how do I wire them ( using only black and red parallel to two jacks )
Thanks again
Thanks again
Re: On Board Amp
Just run short jumper cables to the other jack. 1 to 1 and 2 to 2.
Re: On Board Amp
From the top of this page: install a 4 pole Speakon on the cab containing the amp and one on the extension speaker.
Why you'd only want to use the low frequency amp I don't get.
