On Board Amp
Is this amp OK?
On Board Amp
#1 Post by Bill Fitzmaurice »
This on board amp from Parts Express looks good, at a price that makes sense.
https://www.parts-express.com/dayton-au ... h--300-798
It could be mounted on just about any of our full range cabs with minor modifications. It has enough power to drive a pair of cabs, so it would be easy enough to install a 4 pole Speakon on the cab containing the amp and one on the extension speaker. Full DSP that includes crossover, EQ and limiting plus Bluetooth makes this a very attractive rig.
BrentEvans
Re: On Board Amp
#2 Post by BrentEvans »
Not to mention it has two amps on board, making a biamped cab possible.
mj90210
Re: On Board Amp
#3 Post by mj90210 »
Thanks for the information!
Thank You All for Your Time!!...Really!
2xDR300's
4xDual-30” Tuba 60’s
Simplex 21" Eminence NSW6021
1x20” THT
TLAH‘S
SLA Center-9 driver and Surrounds
SLA pros
TrT 10" Driver-10" Wide
Auto Tuba 10" Driver
Re: On Board Amp
#4 Post by Bill Fitzmaurice »
BrentEvans wrote: Mon Oct 15, 2018 3:06 pm Not to mention it has two amps on board, making a biamped cab possible.
That's the only way you'd want to use it. Until now nothing in this price range had all the features you want, especially the DSP capability.
ACUA
Re: On Board Amp
#5 Post by ACUA »
The first time I saw these amps I though the eq was a 5 preset aka rock pop vocal etc but upon farther investigation it is 5 band parametric with 5 saveable settings. these amps are needed in this industry. That’s a win for parts express and Dayton audio. I wish Dayton made more drivers that met these horn loaded demands.
mino00
Re: On Board Amp
#6 Post by mino00 »
Hello Member
I am building a pair of Jack 10 planing to use this on board amps , what kind of modifications do I need to mount this amp ? Any recommendation .
Thanks
Re: On Board Amp
#7 Post by Bill Fitzmaurice »
It would fit on the side, mounted upright towards the back of the cab.
mino00
Re: On Board Amp
#8 Post by mino00 »
threre are two pair of wire red and black blue and black how do I wire them . If i wire them parallel in to two speaker how do I do it ?Thanks
Re: On Board Amp
#9 Post by Bill Fitzmaurice »
According to the instruction manual.
mino00
Re: On Board Amp
#10 Post by mino00 »
I red the manual from Dayton it did not say anything , I test out the red and black it working fine the blue and black to a second speaker only the tweeter sound . So I will give them a call tomorrow . BTW the amp fit just right on the side of the Jack
Thanks
CoronaOperator
Re: On Board Amp
#11 Post by CoronaOperator »
mino00 wrote: Thu Feb 28, 2019 8:12 pm I red the manual from Dayton it did not say anything , I test out the red and black it working fine the blue and black to a second speaker only the tweeter sound . So I will give them a call tomorrow . BTW the amp fit just right on the side of the Jack
Thanks
Near the bottom of page 4:
Outputs
● 1 XLR output
● 1 High Pass Output (Blue and Black Wire)
● 1 Low Pass Output (Red and Black Wire)
● 1 LED Output Header
Bottom of page 12:
"Notes
● The HIGH PASS output has a passive 1 kHz high pass filter. Even if you turn HPF off in this
menu, the signal is filtered out below 1 kHz. The LOW PASS output can output full-range. "
Re: On Board Amp
#12 Post by Bruce Weldy »
It's even at the bottom of the PE listing....
Specifications: • Amplifier type: Class D • Low frequency power rating (Red/Black wires): 600W RMS (4 ohms/1 kHz @ THD+N 1%) • High frequency power rating (Blue/Black wires): 200W RMS (4 ohms/8 kHz @ THD+N 0.1%) • Input sensitivity: LINE, 0 dBu; MIC, -24 dBu • Bluetooth version: 4.2 • Power: 120~240 VAC, 50/60 Hz, auto-sensing • Dimensions: 15" L x 6-5/16" W x 2-3/4" D • Cutout dimensions: 14" x 5-1/2" • Weight: 5.0 lbs.
mino00
Re: On Board Amp
#13 Post by mino00 »
Thanks
sorry for a dump question , how do I wire them ( using only black and red parallel to two jacks )
Thanks again
Re: On Board Amp
#14 Post by Bruce Weldy »
mino00 wrote: Fri Mar 01, 2019 4:30 pm Thanks
Thanks again
Just run short jumper cables to the other jack. 1 to 1 and 2 to 2.
Re: On Board Amp
From the top of this page: install a 4 pole Speakon on the cab containing the amp and one on the extension speaker.
Why you'd only want to use the low frequency amp I don't get.
