T24 #2
Jake Jarmon
T24 #2
#1 Post by Jake Jarmon »
Checking the fence for each cut - Blade
Bottom
Top
Table Saw make this go SO much faster and all my stock is the same width! I had to bust out the wire wheel and and clean the table off.
All the panels cut out ready to mark, drill, measure, cut, glue, and clamp. :cowboy:
2 - T24 24" BP102 "Twinning"
2 - OT112 Delta Pro 12 Melded Array **In Progress**
Re: T24 #2
#2 Post by CoronaOperator »
That is exactly what my table saw looked like after it was in a flood. I used a belt sander and some aluminum oxide sanding belts and it cleaned up pretty good, then a file for the miter slots.
David Raehn
Re: T24 #2
#3 Post by David Raehn »
You could also use electrolytic reduction to remove all the rust.
Lay a wet towel on the deck and a piece of sheet steel on top of that.
Connect a car battery charger to the assembly, negative to the deck and positive to the sheet steel.
Let it run for a day. (you may have to re-wet the towel, but make sure to turn off the charger when you do that)
Any rust will be converted to elemental iron and will brush off with a nylon bristled brush.
Take a wire wheel to it if you want it to look pretty.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
:noob:
Jake Jarmon
Re: T24 #2
#4 Post by Jake Jarmon »
David Raehn wrote:You could also use electrolytic reduction to remove all the rust.
Science :ugeek:
Re: T24 #2
#5 Post by Tom Smit »
Did you add an extra 1/8" to account for the saw blade width (kerf)?
Jake Jarmon
Re: T24 #2
#6 Post by Jake Jarmon »
Yes, I am dead reckoning to the inside edge of the blade. It has been a very busy few weeks. Got a new job, ran sound and lights at a large theater for a school musical with mariachi. PA was horribly set up and optimized although http://www.sweetwater.com/store/detail/GL2800-848 was fun to mix on. I also rebuilt my dads old Yamaha Club S115 IVs. Anyways I finished T24 #2 and here are some pics!
Marked and drilled
End of day 1
Cab 2 sealed. Forgot to take pics. Ohhhhh man just burly fit :!:
Thinking about putting these flush mount handles here. Any thoughts?
This stuff is amazing and it's only $36 a gallon @ The Depot of Home :slap: . I tinted it slate, the darkest they had.
One down and she approves.
At this point I got side tracked and started working on the S115IVs. They were stored upside down and the floor got wet. The tops started to rot off but they have a lot of sentimental value so I couldn't bear to break em down for parts.
PAINT!!!
Two rebuilt sounding good
Two painted with one coat of textured deckover. I barely put a dent in the gallon. Time to make my ears bleed.
Somebody forgot to load the Vplate :wall: Small choir concert at my wifes school.
Re: T24 #2
#7 Post by CoronaOperator »
Jake Jarmon wrote:Image[/url]
http://s1270.photobucket.com/user/jjarm ... d.jpg.html
Please tell me you played this to 50v with the hatch down :chainsaw: !
J_Dunavin
Re: T24 #2
#8 Post by J_Dunavin »
Not to 50v only 35v.
At 50v the BP102 goes poof!
Re: T24 #2
#9 Post by CoronaOperator »
J_Dunavin wrote:Not to 50v only 35v.
Ooops, my bad. :oops:
Jake Jarmon
Re: T24 #2
#10 Post by Jake Jarmon »
The amp is only capable of 37-40v but the door speakers eat your face before ~ 25v. Doors speakers are running off the head unit. I successfully extended a crack in my windshield this morning on my way to work jamming some Lonely Island. Whoops...
Re: T24 #2
#11 Post by Tom Smit »
:lol: :oops:
