Preferred method of cutting metal grilles
#1 Post by Chris_Allen »
I have plenty of tools, just wondering which is the best method.
Jigsaw? Angle Grinder? New cutting disc in the table saw?
Re: Preferred method of cutting metal grilles
#2 Post by Bruce Weldy »
Chris_Allen wrote:I have plenty of tools, just wondering which is the best method.
Jigsaw with a fine metal blade. Sandwich the grill between two boards right on your cut line.....use the boards as your guide. Quick and easy.
#3 Post by Bill Fitzmaurice »
Circular saw with an abrasive blade, using a saw sled. Screw the grille to the underside of the sled.
sine143
#4 Post by sine143 »
tin snips.
Frederic Gelinas
#5 Post by Frederic Gelinas »
I use a large metal snips. It works great and fast enough, but you have to take precautions not to bend the sheet while you cut. I will try the jigsaw method next time.
Frédéric Gélinas, HF Audio
HFAudio.ca
Free tone Generator
#6 Post by LelandCrooks »
My Bosch powers shears. :mrgreen:
jimbo7
#7 Post by jimbo7 »
Plasma cutter
escapemcp
#8 Post by escapemcp »
Dremel? It's what I used. TBH any small variations on the cut line (and they are small <1mm) soon disappear when you put the grille on the cab. I even started cutting in the row of holes above the row I should have cut... it's missing about 3 or 4 holes, and does not notice.
#9 Post by Radian »
Squaring shear. :wink:
#10 Post by DJPhatman »
Bill Fitzmaurice wrote:Circular saw with an abrasive blade, using a saw sled. Screw the grille to the underside of the sled.
+1 For straight cuts, this is quick and accurate.
Harley
#11 Post by Harley »
Sheet metal guillotine
WB
#12 Post by WB »
Angle grinder with a thin cutting disc.
#13 Post by Tom Smit »
Hello stranger! It's been a long time since you've posted!
WB
#14 Post by WB »
Tom Smit wrote: Hello stranger! It's been a long time since you've posted!
Hey there Tom, glad to see you're going strong. Took a peek around to see what's new and was pleasantly surprised to see Leland has flat packs. Hmmmm ..... looks like some more cabs in my future.
#15 Post by Chris_Allen »
Thanks for the mass of variation on options, it would appear that there isn't really a 'best' option and I just need to use the tools I have.
