Preferred method of cutting metal grilles
- Chris_Allen
I have plenty of tools, just wondering which is the best method.
Jigsaw? Angle Grinder? New cutting disc in the table saw?
Re: Preferred method of cutting metal grilles
Chris_Allen wrote:I have plenty of tools, just wondering which is the best method.
Jigsaw with a fine metal blade. Sandwich the grill between two boards right on your cut line.....use the boards as your guide. Quick and easy.
Circular saw with an abrasive blade, using a saw sled. Screw the grille to the underside of the sled.
tin snips.
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
1x bastard XF208
Frederic Gelinas
I use a large metal snips. It works great and fast enough, but you have to take precautions not to bend the sheet while you cut. I will try the jigsaw method next time.
Frédéric Gélinas, HF Audio
Authorized Builder
HFAudio.ca
Free tone Generator
Authorized Builder
HFAudio.ca
Free tone Generator
My Bosch powers shears.
Plasma cutter
Dremel? It's what I used. TBH any small variations on the cut line (and they are small <1mm) soon disappear when you put the grille on the cab. I even started cutting in the row of holes above the row I should have cut... it's missing about 3 or 4 holes, and does not notice.
Squaring shear.
+1 For straight cuts, this is quick and accurate.Bill Fitzmaurice wrote:Circular saw with an abrasive blade, using a saw sled. Screw the grille to the underside of the sled.
- Harley
Sheet metal guillotine
Angle grinder with a thin cutting disc.Chris_Allen wrote:I have plenty of tools, just wondering which is the best method.
Hello stranger! It's been a long time since you've posted!WB wrote:Angle grinder with a thin cutting disc.Chris_Allen wrote:I have plenty of tools, just wondering which is the best method.
Hey there Tom, glad to see you're going strong. Took a peek around to see what's new and was pleasantly surprised to see Leland has flat packs. Hmmmm ..... looks like some more cabs in my future.Tom Smit wrote: Hello stranger! It's been a long time since you've posted!
- Chris_Allen
Thanks for the mass of variation on options, it would appear that there isn't really a 'best' option and I just need to use the tools I have.
