New THT Build!
Bryson
New THT Build!
#1 Post by Bryson »
Weather is getting nice, so, it's THT time! I've been putting this one off, not sure why... but, I'm starting now... Got the sides cut and drawn out. Cut the access panel. This one's a bit different than the T24s I've made so far. That's all I've achieved so far this weekend. I'll keep this one updated! Thanks guys!
Done: 2 x Dual Loaded T24 (BP102), 2 x 16in T24s (BP102), THT
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#2 Post by Bryson »
Got all the panel pieces cut to width! Time to start making panels...
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#3 Post by Bryson »
Panel 1 is cut and installed. Looks good... the smell of pl brings back memories!
Now: T18...
Next: ???
jimbo7
Re: New THT Build!
#4 Post by jimbo7 »
I really need to make some of those "w" clamps........and buy more clamps
Bryson
Re: New THT Build!
#5 Post by Bryson »
Panel 2 is cut and in! Looking good so far, pretty square...
Panel 3 and 4 this weekend.
Now: T18...
Next: ???
Re: New THT Build!
#6 Post by Radian »
Hope you're prepared for the BIG bottom. :twisted: :wink:
Bryson
Re: New THT Build!
#7 Post by Bryson »
Oh yes! I'm ready. I got rid of all my previous subs... nothing too spectacular but I've had a klipsch and dayton. This one should be sweet!
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#8 Post by Bryson »
Panel 3 has been cut and installed. Looking good. Fit like a glove. Panel 4 and driver spacer next!
Now: T18...
Next: ???
Hackomatic
Re: New THT Build!
#9 Post by Hackomatic »
Driver spacer, huh? You aren't contemplating drinking and drivering, I hope . . . :P
jimbo7 wrote:I really need to make some of those "w" clamps........and buy more clamps
Clamps . . always more clamps . . . I've wondered if it's even possible to have too many clamps.
Dave H
Bryson
Re: New THT Build!
#10 Post by Bryson »
Going pretty well! Today, driver spacer:
And since you guys love clamps so much.......
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#11 Post by Bryson »
Well, didn't get too far today. I was busy and tired. But I did get the baffle drilled and the T-Nuts installed. That step is very important, so it was worth taking my time today.
Here is another shot of the spacer and the PL doing it's job. And if you look close, you'll see a clamp!
Here are the little spacers I made to keep the T-Nuts sucked down... Before this, I test fit the driver. No issues. Looks great.
Here is a shot of the T-Nuts...
This panel should go in tomorrow night. Thanks!
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#12 Post by Bryson »
Well, after looking at the pictures, and reading the plans again, I've made a mistake. I placed the driver cutout 9.5 inches from the wrong end of the panel. So it's closer to panel 1 than it should be. Is this going to change anything, sonically? Should I re-do this panel? It would be an easy fix to flip the panel over, but I cut the 5 degree edge already.
Bill? Any input would be appreciated!
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#13 Post by Bryson »
After some thinking, I can make the other edge 5 degrees as well and flip it over. should meet up ok with the other end. I'll give that a shot. I still wonder though on the effects of moving that driver over.
Now: T18...
Next: ???
Re: New THT Build!
Bryson wrote:Well, after looking at the pictures, and reading the plans again, I've made a mistake. I placed the driver cutout 9.5 inches from the wrong end of the panel. So it's closer to panel 1 than it should be. Is this going to change anything, sonically? Should I re-do this panel? It would be an easy fix to flip the panel over, but I cut the 5 degree edge already. Bill? Any input would be appreciated!
There's no problem so long as the driver still fits into the chamber.
Bryson
Re: New THT Build!
#15 Post by Bryson »
Thanks Bill! I appreciate the reply. I'll test if the driver fits, if not I'll flip it and it should work.
Now: T18...
Next: ???
