Local Sourcing for Carpet and Pet Screen?
- David Carter
Anyone know what type of store might carry carpet and/or pet screen? Since I'm about to do my first build and have never used these materials before, I'd like to go take a look at them in a store before buying to see what my options are.
Thanks.
Thanks.
Dave
- 2 x Titan 39 (BP102 - 14"W)
Pet screen at a True Value hardware store. They can order it if they don't stock it. The small roll is enough for lots of boxes. lI think other folks have found it occasionally at the the big boxes.
Carpet, PE is about the only choice I know of.
- David Carter
Thanks for the tip!LelandCrooks wrote:Pet screen at a True Value hardware store. They can order it if they don't stock it. The small roll is enough for lots of boxes. lI think other folks have found it occasionally at the the big boxes.
Dave
Hi David,David Carter wrote:Thanks for the tip!LelandCrooks wrote:Pet screen at a True Value hardware store. They can order it if they don't stock it. The small roll is enough for lots of boxes. lI think other folks have found it occasionally at the the big boxes.
I got mine at Home Depot. If I recall, you're building some form of Omni right? I've got a bunch left over from my build. Not enough for a screen door (which I'll need soon with a new puppy) but enough for a few more Omnis.
I'd be happy to send you some. Send me a PM.
Doug Danforth
- David Carter
Years ago I re-covered an old Peavey bass amp using grey indoor/outdoor carpet sold by the foot at a hardware store. It looked like amp carpet, at least 1/8 inch thick, flat, with no pile. It looked good and held up great for at least a year of gigs before I sold the amp. But I have no idea if such a thing is still available.
- Frankenspeakers
Might want to look in the local phone book for a place that does automobile interiors or custom upholstry. another idea would be Graingers or McMaster -Carr. (I just got Catalog #113 with 3728 very thin pgs. heh heh heh) I'm sure that there are a few dozen builders who will tell you to fergit the rat fur and go with Duratex. Smells a lot better than the Duplicolor bed liner that Wally World sells. Easier to apply too.
- David Carter
Another PM sent.David Carter wrote:PM sent. Thanks!DrDoug018 wrote:I'd be happy to send you some. Send me a PM.
Dave
