Is it a problem when the outermost brace at least partially blocks the driver from the outside panels?
In other words consider the attached image. Basically the solid outermost braces constricts the expansion(except to the rear/front).
Thanks,
tom
General Bracing Question
Re: General Bracing Question
No, the wave will go around them.tpgreen wrote:Is it a problem when the outermost brace at least partially blocks the driver from the outside panels?
That's a big effin' speaker you are making there
Please post a build log as you go
Actually, this is a big effin speaker - a dual 12", 39" T60.escapemcp wrote:That's a big effin' speaker you are making therePlease post a build log as you go
Putting the THT together feels like assembling a bookshelf speaker after building the mighty T60.
tpgreen wrote:Actually, this is a big effin speaker - a dual 12", 39" T60.escapemcp wrote:That's a big effin' speaker you are making therePlease post a build log as you go
