Inside is one Swamp Thang and one Texas Heat 12" speakers; both made by Eminence and purchased from speakerhardware.com.
My son's intent is to turn it into a combo cab, but rather than a chassis inside holding the tubes and electronics, we'll be putting the amp on top of the cab, tubes up, and with some kind of perf or expanded metal cage around it for protection. Imagine it will end up looking somewhat like a Vox Night Train. That part of the project is still many weeks away from being completed, but I thought I'd show the naked cab anyway.
In anticipation of needing a larger top to accommodate an amp chassis I added two inches of depth to the original plan. All in all a pretty smooth project, with the exception of the shellacking and lacquering of the backside, which I'll talk about towards the end.
Baffles cut and installed, you can see it's to be removable back style.
After getting the speakers in, I decided to leave them in through the rest of the build as I didn't want to risk spinning T-nuts any more than I had to.
That's a Fender Tweed Twin (Low Power) chassis on top as I try to figure out the best way to get the tubes up combo amp that he wants. Abandoned the idea of using an original chassis and have decided it will need to be something custom. But that's part of the fun, too.
You can see the acoustic foam inside the cab in a few of these pictures. Though I've yet to put the speaker gasket tape around the removable back's flanges.
Fitting the removable back piece.
Speakers in.
Grills on. I've left them on, even after installing the framed grill cloth. My understanding is they don't effect sound so I figure the extra protection couldn't hurt. Grills also bought from Leland.
Sizing and cutting the tweed panels.
Practicing my corners.
Covering coming along. Note the "horns" at each top corner. Those are formed because I rounded all edges except the top ones. Keeping in mind that I'd be putting an amp/cage on top I thought it'd be easier and look nicer to mate to straight edges, not rounded ones. We shall see ...
Assembling the grill frame.
Assembly and covering is finished. Now comes the scary part - lacquer and shellac - and I have zero experience finishing and re-finishing furniture. Never knew how much I loved Duratex until I had to take this step.
A few more pics pre-laquer/shellac.
Notice the dog holes in front of the cab. I drilled them into the workbench after the PA project and before this one. Also added front and end flush mounted vices. Really, really helpful. Something one might want to consider if they haven't already done so. Also, see any glue seeping out around the latches? I didn't either. More on that at the end of this posting.
Love the dog holes.
Masked off. My nails by this time are noticeably shorter.
A practice board with the color we're going for. That's plain tweed on the right for comparison.
Actually, it didn't come out half bad.
In these workbench pics the handle is just sitting there, hadn't screwed it down yet.
I had these two handles made for my son by Bob at http://brookwoodleather.com. He also kindly sent me some tweed finishing tips and pics of one of his own builds for pointers. Utilized much of his advice. Didn't come out as nice as his, but still, all in all, I'm reasonably happy with mine for a first time effort. Encourage you to check out his site - gorgeous craftsmanship.There's two handles because after the amp is installed on top, we're going to put the handles on the ends. Until then, however, I've got one handle on top.
Cab looks better in better light than my garage provides:
Okay, time now to confess my sins. The quality of the craftsmanship around here is pretty intimidating for a rube like me, so I almost didn't post the next pics ...
The back came out a bit blotchy. I should have left well enough alone, but there were a couple of stains around the removable back's latches where glue had seeped onto the tweed and the shellac dyes it much darker than dry tweed. In my efforts to correct it, match color, try to rematch again, correct the correction, etc., I probably made it worse than if I'd just told my son to live with it. Good thing is, it's the back. Not the top, front, or sides which I'm still pretty pleased with. (In my defense I will say that the pixelation in some of these pics makes it look a little worse than it really does in person.)
For awhile I was pretty discouraged about it. But once I changed the goal of this project (ex post facto) from producing a cab with a "new out of the box look" to producing one with a "pre-distressed, banged around, late nights in smoky bars for decades" look, I could rest comfortably knowing that I clearly had accomplished my objective. Never underestimate the power of re-writing history.
I'll update this when the amp is complete and installed on it, probably won't be until early 2014 though. Until then, son is going to be driving it with something else. I'll report back with his review as soon as he's had a chance to play with his new toy.
