Let's see your SLA's
jimbo7
#1 Post by jimbo7 »
Just ordered the plans. Looking for ideas as far as finishing goes. Most likely they'll be a flat/semi black so they blend in with the living room, but want them durable enough to use for light pa purposes (parties).
So let's see your SLA's
Bas Gooiker
Re: Let's see your SLA's
#2 Post by Bas Gooiker »
Jimbo,
These are not mine, but some very nice examplesby authorised builders:
But it Herz/Ian Westwood
Funky purple by Patrick Mos
Probably one of the best looking ones where built with dark wood inlays. I can't remember the name of the builder. He was the same guy that did the Otop j-array for his church.
Bas Gooiker
#3 Post by Bas Gooiker »
Found them:
SLA for the HT, by lancemhorseley
These should give you some inspiration for your build. Have fun!
jimbo7
#4 Post by jimbo7 »
Thanks!
That first link is great. The 12th pic down of the baffle speaker centers screwed to scrap so they wont shift when routing is brilliant. Wish I knew that trick before I made my X212.
Benj Ross
#5 Post by Benj Ross »
Here are some Tlah and Sla tha I built for a client. I need to get the pics up for the Sla surrounds too.
http://billfitzmaurice.info/forum/viewt ... 26&t=17230
Benj
http://www.fofg.org
Peavey and Madisound Dealer
Ian Westwood
#6 Post by Ian Westwood »
Benj Ross wrote:Here are some Tlah and Sla tha I built for a client. I need to get the pics up for the Sla surrounds too.
Benj
I really like the black body with wooden baffle look!
Authorized BFM Builder
Bas Gooiker
#7 Post by Bas Gooiker »
I've said it before, but...
Why does everyone ruin their beautiful woodwork with screws through the baffle? There have to be more elegant solutions!
What about these Ikea fixings?
bassmonster
#8 Post by bassmonster »
Bas Gooiker wrote:I've said it before, but...
I think those are where the removable grill attaches, not screws.
anikun07
#9 Post by anikun07 »
Because I followed the instructions?
Benj Ross
#10 Post by Benj Ross »
They are rare earth magnets for the grills. I almost drilled 95% of the way through from the back to glue them in where they could be seen, but I chickened out. Too many hours into them at that point to screw up on the grill mounting. They are pretty low key in real life. Now I am using 1/16" x 1/4" glued to the surface as opposed to 1/8" x 1/4" drilled and mount in the face. Much less time and about the same effect.
Benj
http://www.fofg.org
wallywally
#11 Post by wallywally »
Wood is oak, Finish is Formby's tung oil finish. Baffle is glued and the drivers are loaded from the rear. The tweeters are centered.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
#12 Post by Tom Smit »
Sharp. Very sharp!
Oh, and look, no baffle screws.
biggerrigger
#13 Post by biggerrigger »
wallywally wrote:Wood is oak, Finish is Formby's tung oil finish. Baffle is glued and the drivers are loaded from the rear. The tweeters are centered.
Wallywally What drivers are used in your build?
4-25" Lab12 loaded T39's
2-DR250's Melded array
2-DR250's Flat array
wallywally
#14 Post by wallywally »
4" onkyo closeouts from Madisound. They sold out about 4 years ago. The tweeters are Parts Express onkyo mylar closeouts that are also sold out.
Builds:
T-39
DR 280
Wedgehorn 8
Omni 12
SLA
TAT
TLAH experimental
ketoet
#15 Post by ketoet »
here are my tlah's, haven't got time to build my center sla . but i like to show these whenever i get a chance :hyper:
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
