What Neutrik Speakon Connectors do you use??
But it Hertz
#1 Post by But it Hertz »
I just received a load of these Neutrik NL4MP-ST Speakon Connectors but they leak so much air you can literally breath through them!!!
WTF are they thinking? :chainsaw:
The design is such that you couldn't really seal them after wiring.... unless you went crazy... but then you couldn't easily change it out later.
There are holes *everywhere* Ridiculous!
Anyway, are there any air tight alternatives? What are people using out there? PE URL's appreciated please!
Cheers.
Rune Bivrin
Re: What Neutrik Speakon Connectors do you use??
#2 Post by Rune Bivrin »
Neutrik NL4MP Speakon Connector 4 Pole Panel Mount
Solder or crimp connectors rather than screw connectors, but it's air tight.
Either that or build a small box around the connectors on the inside.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
Bas Gooiker
#3 Post by Bas Gooiker »
+1 on the NL4MP
#4 Post by Radian »
But it Hertz wrote:WTF are they thinking?.
WTF were you thinking?
You bought the panel-mount style...which is supposed to be mounted in equipment racks & wall plates using knock outs where being air-tight isn't an issue. :slap:
Bas Gooiker wrote:+1 on the NL4MP
+2 if you're using metal terminal cups.
Otherwise return 'em and get this style which is intended for mounting directly to a wooden cabinet:
http://www.parts-express.com/pe/showdet ... er=092-054 8)
Zack Brock
#5 Post by Zack Brock »
+1 on the NL4MP
But I source mine from here:
http://www.speakerhardware.com/nl4mp-speakon-jack.php
Zack Brock
But it Hertz
#6 Post by But it Hertz »
OK, cool. Thanks guys :)
doncolga
#7 Post by doncolga »
Zack Brock wrote:+1 on the NL4MP
That's what I've got on all mine too.
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
BrentEvans
#8 Post by BrentEvans »
But it Hertz wrote:couldn't really seal them after wiring.... unless you went crazy... but then you couldn't easily change it out later.
Try silicone sealing tape. It's removable with some effort.
