Question about 500 watt crossover components
djtrumptight
#1 Post by djtrumptight »
Why do we use 500 watt components in our tops when we would never put that much power into them ?
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
Re: Question about 500 watt crossover components
djtrumptight wrote:Why do we use 500 watt components in our tops when we would never put that much power into them ?
Where in the plans does it say you must use 500 watt components?
#3 Post by LelandCrooks »
I have 500w because they're the next step up from the 200w stuff, at least with Erse. 200w is not adequate I feel for the cabs that are using the drivers that can handle 300w, which is actually quite a few of them. Plus a little overkill for durability is not a bad thing.
DJ Higgumz
#4 Post by DJ Higgumz »
i always wondered that too. why don't you just keep the 500 watt to avoid confusion? its only like 5$ more
Building
4 30" T60s
2 19" T60s
1 30" T39
3 Autotubas with GTO804
Bought
2 Dr250s
#5 Post by LelandCrooks »
To some that $5 is important.
djtrumptight
#6 Post by djtrumptight »
I was just curious about it and why the kits come with 200 or 500 watt crossovers.Which cabs can take 300 watts ? I have DR 250's with the premium drivers that i limit at 38 volts ( i know 40 is recommended and 44.7 is the max).
2 SLA HT systems
2 SLA Pro's
DaveK
#7 Post by DaveK »
LelandCrooks wrote:To some that $5 is important.
The 500W inductors are also a lot bigger.
djtrumptight
#8 Post by djtrumptight »
what role will the bigger inductor play ?
2 SLA HT systems
2 SLA Pro's
ncgrove
#9 Post by ncgrove »
Take up more space.
netwerks
#10 Post by netwerks »
Better safe than sorry.
DaveK
#11 Post by DaveK »
djtrumptight wrote:what role will the bigger inductor play?
It will handle more power
