Another tme alignment question
J_Dunavin
#1 Post by J_Dunavin »
Had anyone come up with a chart for time alignment for the Tubas and Titans?
I know that there are a lot of variables, but I'm looking for what the bass line should be. ( ha get it, bass, base :? ya ok)
Anyway it would be nice to say if you have a T24 you need to set in X ms of delay as a starting point.
J_Dunavin
Re: Another tme alignment question
#2 Post by J_Dunavin »
So if my dr's are in roughly the same plane as my T24's, how much delay should i dial in on the dr's?
#3 Post by DJPhatman »
J_Dunavin wrote:So if my dr's are in roughly the same plane as my T24's, how much delay should i dial in on the dr's?
0. None. Nada. Ziltch.
#4 Post by Bruce Weldy »
Doing some quick math on the plans, it looks like the horn path is around 8 feet. So, you can add 7-9ms if you want. Doubt that you'll actually hear any difference.
Now, delaying the subs and the mains to match up with the backline will be much more noticeable.
#5 Post by Bill Fitzmaurice »
Bruce Weldy wrote: Doing some quick math on the plans, it looks like the horn path is around 8 feet.
From which you have to deduct the DR path length. The result is inaudible.
J_Dunavin
#6 Post by J_Dunavin »
Well dang :bash:
For whatever reason i thought that you were supposed to add some in there. Out it comes next gig!
#7 Post by DJPhatman »
:bash: :slap: :horse: :confused:
