TITAN48'S CORNER LOADED
Post links to youtube videos of your cabs.
Forum rules
on1sony
#1 Post by on1sony »
6xBFM TUBA60 30" WIDE
4xBFM DR280's
4xQSC PL325 AMPS
DBX PA+
2xQSC K12 Monitors
AutoTuba 10" Driver (Building Soon)
loudsubz
Re: TITAN48'S CORNER LOADED
#2 Post by loudsubz »
i like the pink BBE DS :)
bradn7
#3 Post by bradn7 »
are you powering that with a QSC 2450 RMX? I ask because I want to make sure that my amp will be able to power them easily.
#4 Post by Grant Bunter »
bradn7 wrote:are you powering that with a QSC 2450 RMX? I ask because I want to make sure that my amp will be able to power them easily.
I'm not sure that the OP will be able to answer you.
I think he is no longer a forum member...
#5 Post by Bruce Weldy »
Here's how you do it.
1. Google QSC RMX2450
2. Follow a link and find out it's wattage rating at either 8 or 4 ohms - whichever you are going to be hanging on it.
3. Go here: http://www.sengpielaudio.com/calculator-ohm.htm
4. Put in the ohms and the wattage. It will tell you the voltage output. If that is more than the plans call for as the voltage limit - you are good to go.....with your limiter hooked up, of course.
bradn7
#6 Post by bradn7 »
Thank you for that page.
escapemcp
#7 Post by escapemcp »
Grant Bunter wrote:I'm not sure that the OP will be able to answer you.
So it FINALLY happened then???
(Sorry guys, out of the loop as I have been away for a few weeks (new job(=new speakers ;))))
Michael Murphy
#8 Post by Michael Murphy »
I think it was just a ban.
