TITAN48'S CORNER LOADED
Forum rules
6xBFM TUBA60 30" WIDE
4xBFM DR280's
4xQSC PL325 AMPS
DBX PA+
2xQSC K12 Monitors
AutoTuba 10" Driver (Building Soon)
4xBFM DR280's
4xQSC PL325 AMPS
DBX PA+
2xQSC K12 Monitors
Re: TITAN48'S CORNER LOADED
i like the pink BBE DS
are you powering that with a QSC 2450 RMX? I ask because I want to make sure that my amp will be able to power them easily.
I'm not sure that the OP will be able to answer you.bradn7 wrote:are you powering that with a QSC 2450 RMX? I ask because I want to make sure that my amp will be able to power them easily.
I think he is no longer a forum member...
Here's how you do it.bradn7 wrote:are you powering that with a QSC 2450 RMX? I ask because I want to make sure that my amp will be able to power them easily.
1. Google QSC RMX2450
2. Follow a link and find out it's wattage rating at either 8 or 4 ohms - whichever you are going to be hanging on it.
3. Go here: http://www.sengpielaudio.com/calculator-ohm.htm
4. Put in the ohms and the wattage. It will tell you the voltage output. If that is more than the plans call for as the voltage limit - you are good to go.....with your limiter hooked up, of course.
Thank you for that page.
So it FINALLY happened then???Grant Bunter wrote:I'm not sure that the OP will be able to answer you.
(Sorry guys, out of the loop as I have been away for a few weeks (new job(=new speakers
Michael Murphy
I think it was just a ban.
