OTOP 112's
chrisrbr
OTOP 112's
#1 Post by chrisrbr »
I love the size and weight of my new OTOP 112's. Anything that makes load in and take down easier works for me. Have gigged with these twice so far. The dispersion is a really nice advantage--could walk anywhere in the bar and the sound was relatively unchanged. The vocals didn't take your head off if you were right in front of the speakers.
Two 20" T39's, 3012LF
Two 24" T39's, 3012LF
Two OTop 112's, 3012HO, melded
Two OTop 212's, 3012HO, melded
http://www.run4coverband.com
chrisrbr
Re: OTOP 112's
#2 Post by chrisrbr »
Here's the rest of the shots:
Hole for pole mount
Hole for pole mount
All done with the Otop112's.  Cheated and bought a set of Otop212's for bigger jobs.
Re: OTOP 112's
#3 Post by Bruce Weldy »
Did you seal around the tophat where it comes through the panel? If not, you should - needs to be airtight.
Re: OTOP 112's
#4 Post by Bill Fitzmaurice »
Bruce Weldy wrote:Did you seal around the tophat where it comes through the panel? If not, you should - needs to be airtight.
It looks like the 3012 option, so there's no venting of the rear chamber into that area.
Re: OTOP 112's
#5 Post by Bruce Weldy »
Picture of the speaker looks like a 2512......but then, I've never seen a 3012HO.....
Re: OTOP 112's
#6 Post by Bill Fitzmaurice »
I was going by the configuration of the phase plug extensions.
chrisrbr
Re: OTOP 112's
#7 Post by chrisrbr »
Hi guys,
It's the 3012 configuration. Pretty sure everything is correct to the plan.
thanks
Chris
Re: OTOP 112's
#8 Post by Tom Smit »
Looks good! :clap:
Where are your reviews?
rec
Re: OTOP 112's
#9 Post by rec »
Chris, What did you use for grill material?
4xT30(24", 4012HO loaded)
1xAT
chrisrbr
Re: OTOP 112's
#10 Post by chrisrbr »
The grills are from Reliable Hardware.com "Custom Speaker Grill - 5/32'' Dia. Staggered - RH-3152" I put a strip of the gasket foam or weather stripping between the grill and the wood. And used rubber washers with the screws. It helped reduce any possiblilty of any rattles.
Wish it wasn't winter here, I would like to go outside and RTA them. They do need a little eq'ing. We have a job in a large banquet hall in a couple of weeks, so that may provide a chance to mess around with the sound when nobody is there. Can't really do that in a bar full of people.
thanks
