One minute epoxy?....think again.
#1 Post by Radian »
When buying epoxy for your t-nuts or h-nuts, stick to the 5-30 minute stuff.
Others here have warned :slap: , but I figured I'd get a little more working time than this....I mean come on?! The grub didn't even make it onto my workpiece.
I broke the internal seal, mixed it for 15 seconds, then pooped out a stupid-hot epoxy turd that nearly melted my flesh. It cured solid before I could even lay down a bead. I've heard of quick set epoxy, but this mix borders on useless. If I had been building speakers, I'd have been most unhappy at the delay of game. :evil:
67baja
Re: One minute epoxy?....think again.
#2 Post by 67baja »
I'm dying here. What a great description of uselessness! "then pooped out a stupid-hot epoxy turd that nearly melted my flesh." Sounds like a bad weekend in Tijuauna.
bassmonster
#3 Post by bassmonster »
67baja wrote: "then pooped out a stupid-hot epoxy turd that nearly melted my flesh." Sounds like a bad weekend in Tijuauna.
:loler: :loler: :loler: :owned:
+1 on the 1 minute epoxy Radian. Even making plastic models it's almost useless, plus it gets really hot as you mentioned.
subharmonic
#4 Post by subharmonic »
+1 to the TJ comment. Been there done that
I need more bass
CW Mcall
BoostFab
#5 Post by BoostFab »
these type of glue are meant to mix right on the area where you would end up applying the glue to; unless you mix a little bit at a time quickly.
