Daisy-Chaining Amps
Daisy-Chaining Amps
When linking amps through the link-out on the amplifier (specifically crown) will the second amp be sensitive to the eq and gain settings on the first amp? Or is it just a straight,flat signal?
Re: Daisy-Chaining Amps
Flat signal. The exact signal that is input into the first amp. EQ must be configured for each additional amp.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Great...Thanks!Lastcat wrote:Flat signal. The exact signal that is input into the first amp. EQ must be configured for each additional amp.
nastyford77
