Hello from Chicago
mikeratliff
Hello from Chicago
#1 Post by mikeratliff »
Ok so I am new to the site/forum but not new to the business though I have been out of the loop for some time. My experience includes design, install of pro-sound and production video systems. I have worked with X Array, VDOSC and some systems from Martin and Macpherson. I have done large and small concerts from metal to classical and all in between. All this leads to an idea....I hope to build and make available excellent audio systems for musicians starting out in the business. My mission is not to replace the biggies such as DB Sound and Gand Concert Sound. There are multiple companies to rent from but I am looking to fill a niche. So I got questions....I have always done my best to design systems on the K.I.S.S. (keep it simple stupid) principle. I have been researching all the manufacturers and their line arrays and I am amazed at the complexity, computer software to aim and calibrate systems and so on etc.. My question for now is, DR300, how does it measure up to say a Butterfly from Outline or the new Nexo rigs. I can read the SPL's and other data and I know that it will more than do the job for most if not all of what I plan for it but, having never actually heard a system based on the DR I need your input. I worked with Charlotte Church (7K seating on average) with a VDOSC and the clarity was phenominal. So how does the DR measure up to the ear not just on paper. Thanks and sorry for the wordiness.
Dantreige
Re: Hello from Chicago
#2 Post by Dantreige »
You should fill in your location. Someone near you might be able to give you a listen.
And welcome!
Once you go Jack, you never go back!
Done:
(2) Jack 12, 3012ho, Straight Array with On/Off Switch
In Process
(4) Dr200 Beta 8, Melded Array
#3 Post by Tom Smit »
Welcome to the forum, Mike.
Dantreige
#4 Post by Dantreige »
Doh! I should learn to read. :) Lots of folks from Chicago area that have BFM cabs. Check out the Come Hear Them Section. http://billfitzmaurice.info/forum/viewforum.php?f=15
Done:
In Process
mikeratliff
#5 Post by mikeratliff »
I checked the come see it and did not see any chicagoland events...I will be going to Mayhem Festival this friday and will be looking over the systems...will probably be the oldest metal head there.
