xti eq
subharmonic
xti eq
#1 Post by subharmonic »
What is the difference between the input and output eq on these. I couldnt find much info on it. Which should i be using?
I need more bass
CW Mcall
netwerks
Re: xti eq
#2 Post by netwerks »
output.
jcmbowman
Re: xti eq
#3 Post by jcmbowman »
use the output EQ. the input EQ lets you adjust the signal before any other DSP or signal routing, so it's pre-HPF and LPF, limiter, etc.
4 DR250s
4 Tuba36s @ 30" wide
2 ATs
subharmonic
Re: xti eq
#4 Post by subharmonic »
So why would you eq before processing? I guess i am trying to figure out the point of 2 eqs.
I need more bass
CW Mcall
Re: xti eq
#5 Post by Tom Smit »
subharmonic wrote:So why would you eq before processing? I guess i am trying to figure out the point of 2 eqs.
I was wondering that as well. Anybody?
subharmonic
Re: xti eq
#6 Post by subharmonic »
Originally I figured the output one was just the one going out the line levels outs. I thought well that is nice so I can EQ another amp but I couldn't find any info on it. It probably is staring me in the face, sometimes those are the hardest things to see.
I need more bass
CW Mcall
cheapbasslovin
Re: xti eq
#7 Post by cheapbasslovin »
If you are having a specific frequency that is hitting the limiter while the rest of the spectrum has plenty of headroom, you can duck that specific freq on the preEQ without dropping the overall levels. I'm not familiar with the XTi personally, so I don't know how practical this could be in real life, or which other features might be affected by the pre-EQ, but this is one reason you might use the preEQ.
Mrrmensneturguneffferremantun
Re: xti eq
#8 Post by AntonZ »
You can use them any way you like, but I would use the output EQ for straightening your cab's response. The input EQ for correcting the room, notching out room modes, things like that.
Re: xti eq
#9 Post by Tom Smit »
Thanks guys! :clap:
subharmonic
Re: xti eq
#10 Post by subharmonic »
AntonZ wrote:You can use them any way you like, but I would use the output EQ for straightening your cab's response. The input EQ for correcting the room, notching out room modes, things like that.
I can see that. Thanks for all the responses. If nothing you have whole second set of EQing you can do if the original 7? bands aren't enough.
I need more bass
CW Mcall
