Lock Washers
doncolga
Lock Washers
#1 Post by doncolga »
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
WB
Re: Lock Washers
#2 Post by WB »
Make sure they're high collar lock washers, when using socket cap bolts.
Re: Lock Washers
#3 Post by Bill Fitzmaurice »
Not so much. These are better:
monekh
Re: Lock Washers
#4 Post by monekh »
Bill, or anyone else - would you recommend using 'starlock' washers
http://www.ebay.co.uk/itm/2mm-3mm-4mm-5 ... 4d14b8a0a1
over regular toothed lock washers
http://www.ebay.co.uk/itm/m3-4-5-6-8mm- ... 3a7cdf7d84
or are they likely to perform much the same when it comes to ensuring bolts securing the driver in place (in a T60) do not shake loose?
Cheers
Rune Bivrin
Re: Lock Washers
#5 Post by Rune Bivrin »
monekh wrote:Bill, or anyone else - would you recommend using 'starlock' washers
Cheers
The 'Starlock' washers have a completely different purpose. They're for slipping onto an axle to prevent movement along the axle while allowing rotation. Fuggedabootit!
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
monekh
Re: Lock Washers
#6 Post by monekh »
Thanks for putting that one to bed Rune!
