I found a pic that Brent posted a while back, that was set Flat, using SAC.
Transferred all the Settings Manually into Band Manager for the DR200's. Nice and flat. I have included a Preset File for the DR200's, there are about 7 different settings, including Brent's Settings. The 7 different settings are based off of Brent's pic above, and tweaked and changed a bit here and there.
Now mind you, this is just a starting point, every venue will change, walls, floors, ceilings, etc... At best, RTA's would be more helpful, then of course good old "By Ear" settings. But so far, I have found a few of the presets to really so far make the DR200's Shine.
The presets are for the Crown XTi 4000, so you would have to double check the limiter, and of course your XO's, and whatever else needed. I haven't found a way to export or import a single amp setting yet, someone know? Oh well, give this a try, and see how they work for you.
I have the same file in RAR and ZIP Format. Just download to a folder, then in Band Manager, select your Amp, then Open Preset filename: DR200.XTi
https://home.comcast.net/~lastcat/forum ... 00.XTi.zip Zip
https://home.comcast.net/~lastcat/forum ... 00.XTi.rar Rar
