Is it ok to mount a 1/4 jack on the back. It won't be sealed if I install it, but than there's already
3 vent ports, does it matter?
Sealing the 1/4" jack on my ot12 build?
T39 / OT12 Bass rig
2 T-48
4 DR250, 6 T-48 in the works
2 T-48
Ken Lustgarten
Re: Sealing the 1/4" jack on my ot12 build?
IMHO just use speakon jacks. If you do install the 1/4" jack it will not be to bad as long as there is a speaker wire plugged in. If you install 2 jacks and are only using 1 I would plug the unused jack. A small box can always be built in the back to seal off the jacks.
wounded horse
Why does anyone use jacks on any speaker cab? Speakons lock, are airtight and have a positive electrical connection. It's a no brainer.
