Setting up the BBE DS48 (pictures) any comments/help thanks!
loudsubz
#1 Post by loudsubz »
Just got around to setting up my new DSP.
I am running 2 X Titan 39 (3012LF Loaded) and 2 X Otop 12 (Delta Pro 12a) Loaded
Here is the setup I have thus far.
Initial Setup. I have Channel A and B as the 2 main inputs from my mixer. Out 1 and Out 2 are for the Otops. Out 3 and out 4 are summed for my Titans.
My Top Corssover
My Sub crossover
Delay (I put 7ms but wasn't sure what to play around with)
Gains are all 0
Limiter I left default but need to fix that
Last we have the PEQ, I wasn't sure what to tweak there.
Monomer
Re: Setting up the BBE DS48 (pictures) any comments/help tha
#2 Post by Monomer »
Looks alright.
Crossover settings will change per room. Acoustic vs. electric. (covered elsewhere)
I usually have one single sub out, and run the amp in parallel output, less wiring.
-More to come!
loudsubz
#3 Post by loudsubz »
Thanks.
What about the PEQ setting? Is it something that should be tweaked by ear after listening? I know for the GEQ its suggested to do the opposite of the response graph than do some slight tweaking by ear after.
#4 Post by Tom Smit »
Probably pretty much the same way. And you can use the Q to widen or narrow the width of cut/boost.
