BBE DS48
wounded horse
BBE DS48
#1 Post by wounded horse »
Any comments/recommendations/avoid like the plague on this DSP box? All replies welcome as there's one on ebay now with 2 odd hours to go.
SeisTres
Re: BBE DS48
#2 Post by SeisTres »
BBE is a nice brand for that. It's on the same level as the lower lever dbx processors (dbx driverack pa). I believe monomer and someone else run this set up. Some prefer them over the behringer ones.
loudsubz
Re: BBE DS48
#3 Post by loudsubz »
I picked up one 2 weeks ago for $200 cdn.
It was basically brand new just opened to test the box to see if it was working (was a return as his original had taken a brown out and messed up the power supply).
I am tweaking it now and going to use it. From the research I did it was a little limited on features compared to the DCX2496 but from what I could tell people were happy about is reliability and rock solid performance, that was a bigger factor to me.
Monomer
Re: BBE DS48
#4 Post by Monomer »
I love mine, for the money.
I have blown it up, running at low voltages (96VAC on the furman) BBE replaced it with a new unit, all in less then a week.
The only downfall is the limited delay and non-graphic eq's. Otherwise, it's a fantastic unit.
-More to come!
BrentEvans
Re: BBE DS48
#5 Post by BrentEvans »
Monomer wrote: The only downfall is the limited delay and non-graphic eq's. Otherwise, it's a fantastic unit.
You can actually tune with parametric EQ far more precisely than with a graphic. It's just a learning curve.
Re: BBE DS48
#6 Post by AntonZ »
BrentEvans wrote:You can actually tune with parametric EQ far more precisely than with a graphic. It's just a learning curve.
Is that similar to the smiley curve?
BrentEvans
Re: BBE DS48
#7 Post by BrentEvans »
Complete opposite, actually. :owned:
Monomer
Re: BBE DS48
#8 Post by Monomer »
only 5 bands per output.
lot harder to tweak on the fly.
-More to come!
SeisTres
Re: BBE DS48
#9 Post by SeisTres »
This is exactly why I decided against the dcx. Everything was going perfectly and almost added it to the cart but once I read it did not have the 31band eq, I took the dbx in a heartbeat.
