DR250 first build
mino00
DR250 first build
#1 Post by mino00 »
Hello all .
After long debate with many good review for DR250 so I decided to to go with it . It kind of confusing at first, so I took one step at the time cut all the parts first dry fit and it make sense . attached couple pics. Help me out if you see any mistake that I can correct at this state .
Ps : After glue the tweeters it measure 21 1/8 . In the plan said 21 in or less so what should I do .
Thanks
Henry
Re: DR250 first build
#2 Post by LelandCrooks »
Finish it. Extend the plate either at the top and bottom of the array cutout to fill the extra gap.
mino00
#3 Post by mino00 »
Thanks
I will do that tonight.
Henry
djtrumptight
#4 Post by djtrumptight »
If you havent assembled those parts yet,you can adjust the height of the cabs by trimming according to the plans to make the cab tall enough in the front,acceptable height is 21-21 1/2 inches so you are good.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
mino00
#5 Post by mino00 »
I got it , anyway how to apply the poly fill
Thanks
