Acoust-X - Anyone use?
Kirk Baptista
#1 Post by Kirk Baptista »
Hello, all!
I was looking into using spray foam or something like it for damping the inside of my Jacks, when I saw Acoust-X on the Duratex site.
http://www.acrytech.com/catalog.asp?pro ... prevnext=1
Anyone use it, or have any experience with any other spray on foams?
Thanks!
Kirk
Custom Fender 5 string PBass
Ibanez SD 530 4 string
Gallien Krueger MB Fusion
2 Jack Stack, Kappalite 3012HO
Re: Acoust-X - Anyone use?
#2 Post by DJPhatman »
Usable, but very expensive. Cheap mattress toppers are the norm.
Kirk Baptista
#3 Post by Kirk Baptista »
Yeah, I expect I'll end up with a topper, but I can't seem to find a black one... I know, I'm picky.
The Acoust-X seems like a better way, just brush on, etc. and for $25 a gallon, it seems as cheap as foam. I expect a gallon would go pretty far just doing insides. But then, it's not better if it doesn't work as well. I thought someone here must have tried it. The data sheet states a 30% reduction in reflections, and I didn't know if that was sufficient. It seems like you would get more than that with foam. I figured someone on here must have tried it and could shed some light...
#4 Post by Tom Smit »
Kirk Baptista wrote:Yeah, I expect I'll end up with a topper, but I can't seem to find a black one...
Use paint.
#5 Post by Bill Fitzmaurice »
Kirk Baptista wrote: The data sheet states a 30% reduction in reflections, and I didn't know if that was sufficient...
It isn't. In the upper midrange where damping is most critical the recommended materials are over 70% effective.
#6 Post by LelandCrooks »
I have it, I've used it. I keep intending to do some testing with it. That whole roundtuit thing. I use it for dampening in DR's, because I primarily build with the butt cheeks from aluminum. I coat them about 1/4" thick. It weighs virtually nothing. Crazy stuff.
camrynekai
#7 Post by camrynekai »
Kirk Baptista wrote:Yeah, I expect I'll end up with a topper, but I can't seem to find a black one... I know, I'm picky.
I use fabric dye on my toppers.
Facebook Page
My herd of T48's
Cabs built
14- 24" T48's 3015LF's
4- OTop 12's W/melded array's
2- 29" Sla Pro's
1- Auto tuba ITW
Kirk Baptista
#8 Post by Kirk Baptista »
Ah excellent. Toppers with fabric dye. Perfect. I didn't want to paint and make them all crusty. I know, doesn't matter, except to me.
Thanks for all the info.
BrentEvans
#9 Post by BrentEvans »
Gray foam toppers are here and there, and the shadows inside the box do the rest.
