NEED HELP SETTING I-TECH8000 EQ FOR 36" TITAN 48'S ATLANTA
djpk
#1 Post by djpk »
I was wondering if there's anybody in georgia knowledgeable enough to help me set up my ITECH 8000 WITH MY TITAN 48'S
I HAVE 2 36" dual 3015LF loaded Titan 48's completed
and 2 more that will be completed in a few weeks
they are series wired so each box is 16 ohms
i also have a v-plate with proper clamps
1- I-TECH 8000 dedicated to the subs
if your willing to help please let me know thanks
4 36" dual 3015LF Titan 48's
Future build:
4 MORE Dual Loaded Titan 48's 3015LF 36" wide
6 Dr 280's Currently in build
Powered by: Titans - I-tech 8000
(2) XTI - 4000'S
http://www.mrdjpk.com
Re: NEED HELP SETTING I-TECH8000 EQ FOR 36" TITAN 48'S ATLAN
That large of a rig will run so flat that no pre EQ should be necessary. It would only need room correction.
el_ingeniero
#3 Post by el_ingeniero »
72" of v-coupled and plated T48. That's taller than I am. Sick. You need to be posting a picture of your rig in action.
Make sure you have the latest firmware for your I-Tech. Go here: http://www.crownaudio.com/software.php?showtopic=285
You will need the IQwic software installed on your laptop to run your amp. You hook up the amp and the laptop to a wired ethernet hub, and fire up the IQwic software to control the laptop.
With 4 16 Ohm cabs plus the horn impedance, the I-Tech 8000 will be very comfy running at 4 ohms, so go ahead and parallel all 4 cabs and set up the amp in bridge mode. That might be a switch on the back instead of something in the software interface.
From there, dig around in the software to see where to set up a limiter and a highpass filter to protect your drivers.
#4 Post by Bruce Weldy »
No need to bridge with the I8000. 2100 watts per side at 8 ohm (two cabs per side) - gives each speaker 525 watts. You could run 'em all on one side - that's 4000 watts at 4 ohms or 500 watts apiece.....then you could run the rest of the world with the other side.
