subwoofer pole socket
brodave2
#1 Post by brodave2 »
a lot of subs have pole cups in them, so you can put a pole in it and mount your mains on the pole. Has anybody been inside one of those? Do they have extra bracing, or do they just have a pole socket bolted in to the top?
Re: subwoofer pole socket
brodave2 wrote:a lot of subs have pole cups in them, so you can put a pole in it and mount your mains on the pole.
They shouldn't, as that encourages poor sub placement.
Greg Plouvier
#3 Post by Greg Plouvier »
Usually they're just bolted on with t nuts mounted inside the cab. There is a backer plate available for some pole sockets for extra reinforcement. Of course you want to make sure to seal it up good.
Greg Plouvier
brodave2
#4 Post by brodave2 »
If you saw the cramped quarters I've been working in lately you'd be looking for something to compact your setup too! Stages 6' deep and 15' wide with a 4 piece band and singer. Tables set up right beside.
#5 Post by Bill Fitzmaurice »
brodave2 wrote:Stages 6' deep and 15' wide with a 4 piece band and singer. Tables set up right beside.
That's about average for stage size. Aim PA tops at the nearest tables and no one will sit there anyway.
