Out of curiousity why do we countersink screws, if they are pulled out after the PL has set?
I can see why we drill piolot holes to avoid splitting.
Some of the plans mention to countersink deeper on end panels so you can round over with a router but from I gather, most people remove the screws.
Why countersink screws?
Re: Why countersink screws?
Countersinking is only useful if the screws stay put. If you pull them out, then don't bother.
I countersink because a screw bit pilots and countersinks, and the bit won't drill the pilot to full depth without countersinking. A simple straight bit doesn't drill a good pilot as it doesn't make the hole larger at the top to fully clear the screw shank.
- Drey Chennells
most definitely and you risk breaking your screws head with a pilot no countersink..Bill Fitzmaurice wrote:I countersink because a screw bit pilots and countersinks, and the bit won't drill the pilot to full depth without countersinking. A simple straight bit doesn't drill a good pilot as it doesn't make the hole larger at the top to fully clear the screw shank.
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
InfraCoustik
Thanks for the responses.
I countersunk my screws so far but after pulling the screws out it got me wondering.
The only thing i've contersunk was the four 8 screws for my sla baffles, but other than that, i never counter sunk anything and it does the job. Even with BB, I still didn't coutersink and never had any problems whatsoever.
- Harley
You want to try unscrewing them, much easier than pulling them out.bean438 wrote: after pulling the screws out it got me wondering.
- jswingchun
Harley wrote:You want to try unscrewing them, much easier than pulling them out.bean438 wrote: after pulling the screws out it got me wondering.
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
