From that it gets divided up and goes to the appropriate amps than speakers.
Follow so far?
For my lead singer, he gets a channel off the amp to run his 2 Wedge 10's. (I know its a lot but that's another story).
The other channel is for the bassist W10 and for the lead guitarist's W10, both in line daisy chained.
It worked out great till my guitarist got a new toy and requires a different mix in his monitor. And my bassist got a V amp and is going to run through the PA instead of a back line. He is going to want more bass in his W10. BUT here is the catch, my guitarist doesn't want more bass so I can not supply a different mix to each.
I got a solution but need your advice.
Do I go from the DCX back into the board than out the back via speakon to the one W10?
Or do I go directly out the board and bypass the DCX to the W10?
And when I do this will the monitor 1 and 2 pots be controlling this?
