Sure amps
DJ Big Ronn
Sure amps
#1 Post by DJ Big Ronn »
The spec says that they can run on a wide range of voltage. If using them in the car, can you just hook them up to 12 volts, or do you have to buy the power supply?
Doug Hart
Re: Sure amps
#2 Post by Doug Hart »
yes, you can hook them straight to your 12v. Through a fuse of course.
Doug Hart, Owner
dB Pro Audio
http://www.hartdesignsetc.com
Sydney
Re: Sure amps
#3 Post by Sydney »
Revision
From
http://www.sureelectronics.net/goods.php?id=960
The page says
# Operating voltage range: 10V-30V, the maximum voltage of power supply is 32V
But later says
"Only use approved high quality DC power supply. The use of other adaptors or supplies could seriously damage the Amplifier board. 24V DC 14.6A 350W Regulated Switching Power Supply is recommended."
From the Comment section:
" In theory the amplifier could be powered by 12V 3A or more power supply. It is recommended to power it by 27V 350W MW power supply."
Administrator:huangrongkui
( There is nothing like good clear concise Tech support :roll: )
Syd
DJ Big Ronn
Re: Sure amps
#4 Post by DJ Big Ronn »
Hmmm, so i wonder if i should try, or get the supply that im not sure that i need?
Doug Hart
Re: Sure amps
#5 Post by Doug Hart »
I think it will work ok, but you won't get the max output from the amp with only a 12v power supply
Doug Hart, Owner
dB Pro Audio
Sydney
Re: Sure amps
#6 Post by Sydney »
From Comments...
" What is the output @ 4 Ohm 12V DC supply? Chendy 2010-05-18 04:04:09
When you use "12v supply @ 4 ohms", the RMS value of output power of each channel is no more than 18W. "
Performance degradation as well
http://www.sure-electronics.net/downloa ... 1.0_EN.pdf
Overcurrent shutdown is reduced, S/N Ration and Channel Separation figures of merit are reduced.
It appears to be optimized for higher voltage hence the statement
"24V DC 14.6A 350W Regulated Switching Power Supply is recommended."
Syd
DJ Big Ronn
Re: Sure amps
#7 Post by DJ Big Ronn »
So if I were to buy two of the four channel amps, could i power both of them with one power supply?
djeccentric
Re: Sure amps
#8 Post by djeccentric »
you could build or buy a voltage doubler to boost the voltage from 12-24 volts. i'm not sure how to do this but i know it can be done.
