EAW's new dual 21" sub
Re: EAW's new dual 21" sub
#1 Post by Radian »
Check out similar offerings from Danley:
http://www.danleysoundlabs.com/pdf/TH%2 ... 0Sheet.PDF
No DSP required.
WiSounds wrote:The "Calculated Axial Output Limit", could these numbers be suspect?
They are just that...calculated. The math certainly works on paper, just like we do it here. However, that raw response curve without DSP is a pretty solid indicator of the cabs potential, given it's vented alignment.
WiSounds wrote: The "Calculated Axial Output Limit", could these numbers be suspect?
Calculated output = :bull:
And it's got nothing over the T60, except price.
DJ Big Ronn
#3 Post by DJ Big Ronn »
I bet they can be had for the price of a pair of T-48's too. :broke:
djtecthreat
#4 Post by djtecthreat »
EAW Engineering: "Hey we can't possibly get anymore out of the Eminence 18's we use in all our designs"
Boss: "Ok, well then make them 21's, redesign the same box, mark up the price, and we'll get these things on every rider from here to California!"
I say this... and I own EAW speakers.
DJ TecThreat
-Building-
8 More T48's
-Built-
4 SLA Pro's
sine143
#5 Post by sine143 »
I will say, Its surprisingly small (given that could also be a bad thing) and at weighs 100 pounds less than I expected to see when I read the title to this thread (200 pounds). Power handling is ridic, but you know... power compression lol. I'f you've got a small venue.... and monies.... it could be the way to go.
But if you have rooms for T60s, choice is obvious.
DJ Big Ronn
#6 Post by DJ Big Ronn »
I saw 1499.99, but that doesnt sound right
sine143
#7 Post by sine143 »
thats cheaper than the SB1000? a good deal cheaper it seems.
#8 Post by Bill Fitzmaurice »
DJ Big Ronn wrote:I saw 1499.99, but that doesnt sound right
That's less than half the SB1000, so not likely. Curiously no price appears for it anywhere.
sine143
#9 Post by sine143 »
yeah, i mean, even at way off retail the 1000 is like 2600 or more.
waiting for the price :noob:
