Behringer DEQ2496
coolhandjjl
Behringer DEQ2496
#1 Post by coolhandjjl »
Seems like a sweet unit. So really all you need to EQ a room is this and the ECM8000? No laptop with RTA software anymore. Anyone using one here?
John Luke
Pair of Omni 212's
Scott Brochu
Re: Behringer DEQ2496
#2 Post by Scott Brochu »
I have one and still trying to figure it out. I have yet to get the mic. But am using it like my 31 band.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
#3 Post by LelandCrooks »
I have 2. I use them every time. The peq, the geq, limiters and compression. I haven't used the rta in a long time. I have a flat curve for the rig I run, I punch it up and tweak to taste.
coolhandjjl
#4 Post by coolhandjjl »
How about for non-PA use like on a home system? Will it automatically sense non-balanced loads, like fron RCA plugs from home systems?
In a situation where you may have done some cuts, are you able to bring the overall gain back up to a similar SPL before the EQing?
John Luke
Pair of Omni 212's
#5 Post by LelandCrooks »
That's pretty simple with it. I don't think it will auto adjust for unbalanced lines. I know lots of ht guys use the DCX2496 xover, which is the companion piece. No reason it wouldn't work in that application.
#6 Post by AntonZ »
coolhandjjl wrote:How about for non-PA use like on a home system? Will it automatically sense non-balanced loads, like fron RCA plugs from home systems?
Yes to all. I think it does auto adjust for unbalanced. It is in the manual IIRC (available for download from the Behringer website).
WB
#7 Post by WB »
coolhandjjl wrote: In a situation where you may have done some cuts, are you able to bring the overall gain back up to a similar SPL before the EQing?
Yes.
coolhandjjl
#8 Post by coolhandjjl »
I just found a review where they guy made some RCA/XLR connectors. (I guess he wasn't near a Rad Shack)
http://www.enjoythemusic.com/magazine/e ... ve2496.htm
So I guess this thing is great for home and on the road!
Thanks for all the help!
John Luke
Pair of Omni 212's
Zack Brock
#9 Post by Zack Brock »
coolhandjjl wrote:I just found a review where they guy made some RCA/XLR connectors. (I guess he wasn't near a Rad Shack)
All the Radio Shacks in my area no longer stock items to make your own cables and connectors. If the Radio Shack is still open, all they have become is a glorified cell phone store. What a waste.
Zack Brock
#10 Post by AntonZ »
Yep, it is a nice piece of kit. See paragraph 5.2 (p.19) in the DEQ manual for description of auto-correct levels when connected to unbalanced equipment (home audio).
I made my own XLR to RCA adapters for using the DEQ at home, cost me just a few € each. Cold and ground wired together to the ring, hot to the tip.
Some people have reported issues due to failing power supplies and DOA units. My first one was DOA, got a replacement and that one hasn't failed me yet.
coolhandjjl
#11 Post by coolhandjjl »
AntonZ wrote:Yep, it is a nice piece of kit. See paragraph 5.2 (p.19) in the DEQ manual for description of auto-correct levels when connected to unbalanced equipment (home audio).
So are commercially available adapters are not correct, I need to make my own?
What type of XLR mic cord does the Behringer ECM8000 mic need?Is it a male to female? Male to male?
John Luke
Pair of Omni 212's
#12 Post by AntonZ »
coolhandjjl wrote:
AntonZ wrote:I made my own XLR to RCA adapters for using the DEQ at home, cost me just a few € each. Cold and ground wired together to the ring, hot to the tip.
I do not know, as I have never purchased these adapters. If you purchase you can ask the seller how the adapter is wired.
Standard mic cable, male to female.
juicewon
#13 Post by juicewon »
just picked up a deq and was wondering if the limiter functionality was adequate enough or if i would still need to spring for the companion dcx?
j
on first builds!
Otop12s
T60s
el_ingeniero
#14 Post by el_ingeniero »
juicewon wrote:just picked up a deq and was wondering if the limiter functionality was adequate enough or if i would still need to spring for the companion dcx?
j
If Leland is using it, it prolly is.
#15 Post by DJPhatman »
j
IIRC, the DEQ does not have a limiter function. The DCX does.
