6 x WH8 MkIV build in 2 lots of 3. Completed.
Re: 3 x WH8 build.
#76 Post by Grant Bunter »
heavybdrums wrote: Thanks sooo much for posting and linking your build thread for us. I am in the process of building 2 wh 8's with the delta pro 8a drivers and also would like to paint the tweeter arrays. How did you prepare them for painting?(do you have to remove the elements from the back to do this ?).
No worries.
Yes, to paint the piezo's, remove the screws from the back and carefully remove the back and the element. Set them aside somewhere safe while you paint. I used rattle tins to paint mine.
I recommend to remove the screws by hand (ie with a screwdriver) and put them back in the same way. You don't want to strip the piezo bodies. Don't ask me how I found that out!
heavybdrums wrote:also a newbie question about forums here: i am having problems posting pictures on here, when i try to it says the image is too large to post. How can i get pictures to post on here ?
Just to show you, hit the quote button on your reply above this post.
You'll see links to my photobucket account for the image. That's how I put up images.
You can upload images directly to the forum, but the pics have to be the right size.
Not a problem with photobucket.
Upload to photobucket, upload, go to the pic, right click the [IMG] line (should say "copied"), then paste.
heavybdrums wrote:Curious about the grille material, is it just hardware store bought expanded metal?
We're not as fortunate here in Australia, we don't get such items at our local hardware.
Mine was ordered from the manufacturer via a reseller. I bought an 8 x 4 sheet.
Yes, it's expanded aluminium, the aluminium itself about 1.6mm (roughly 1/16") thick. I got the non flattened style, it cost less.
Any Aussies wanting to get the same material, the manufacturer is the Lockyer group and this is the 12/20 product IIRC...
heavybdrums
Re: 3 x WH8 MkIV build. Completed.
#77 Post by heavybdrums »
so in Australia you call them rattle tins..I like it, here we call them spray bombs or spray cans in Virginia. Spray bombs due to what they do when put in fire..lol. Thanks again for all the info. Now that i know how to post pictures, some coming soon.
4x WH8 delta pro
2x WH10 Deltalite 2510
4x Dr250 Deltalite II 2510
8X Titan 39 3012lf, 28"
4X Tuba 60 W/ lab 15
#78 Post by Grant Bunter »
Updated, replaced photobucket hosted pics wherever possible...
Re: 6 x WH8 MkIV build. 3 x Completed.
#79 Post by Grant Bunter »
Well, here we go again.
3 was enough way back when, but I'm doing more, with increased foldback requirements at times (sends and consequently cab count), but not enough cabs.
Today, began cutting up ply for 3 more.
Drivers sourced/purchased (Beta 8A). Small interlocking Penn Elcom corners sourced in Australia.
Right now, shipping, import charges and the time it's taking for orders to arrive from overseas are not representing any significant savings at all.
Over the last couple of years I've managed to get some trade accounts. One, an electronics supplier, covers Neutrik, Dayton amongst other things, including Daichi 1016's. Pretty much identical to Goldwoods, but 3K instead of 3.5K for the goldwoods, and up.
Same prices, or better, and local shipping.
So, everything is going to be sourced in Australia (except PL damn it, lucky I have enough).
Sorry Leland.
I was thinking 5, but that's stretching the budget a bit for now.
Stay tuned...
#80 Post by Grant Bunter »
Drivers arrived.
Ordering filter components, speakons and 1016's today.
Ply mostly cut up.
Things are progressing...
jimbo7
#81 Post by jimbo7 »
So what do the bandmembers think of the WH8's? I've been wanting to make some for a semi-pro keyboardist and her bandmates. Probably the vocal model. Can you mix the vocal and full-range version?
#82 Post by Grant Bunter »
Well, nowadays it's artists and support players.
The WH8's do vocals really well, clear and crisp, but I try to stay away from full mixes with them (and no bottom end below say 125Hz).
I wouldn't put a keyboard players left hand into a WH8 and expect it to cover that well.
The WH10's are the full range cabs.
While the 2 have different phase response, I guess you could make them work together...
Re: 6 x WH8 MkIV build in 2 lots of 3. Completed.
#83 Post by Grant Bunter »
Well, nearly twelve months later, the second trio are done!
The build was essentially the same as described earlier, cut up all three, assemble one, then assemble two.
In testing, at lower power, and a little tweaking, these monitors surprised me again at their full range capability.
Just in time for the gig they are required for on Friday...
#84 Post by Grant Bunter »
p.s they all have foam on the back of the grilles now, gone stealth...
#85 Post by Tom Smit »
Looks good, Grant!
Good to see you back! Missed your input for the last bunch of months.
#86 Post by Grant Bunter »
All 6
#87 Post by Bruce Weldy »
Nice looking cabs, Grant. We've missed you!
