New THT Build!
Bryson
Re: New THT Build!
#61 Post by Bryson »
Forgot to tell you guys, I'm not using PL. I'm using something else that was recommended to me by my buddy...
Also, don't worry, i'm not bass hungry during this build. I V-Plated these guys:
Done: 2 x Dual Loaded T24 (BP102), 2 x 16in T24s (BP102), THT
Now: T18...
Next: ???
67baja
Re: New THT Build!
#62 Post by 67baja »
Bryson wrote:Forgot to tell you guys, I'm not using PL. I'm using something else that was recommended to me by my buddy...
:loler: BILL, I think we need a plan update with this new fangled glue stuff. It looks easier to dispense than that nasty PL. Very funny stuff there Bryson :clap: !
Melifluonze
Re: New THT Build!
#63 Post by Melifluonze »
Your build is fantastic!
I guess I beat you after all... by a hair... just turned it on.. still catching my breath...
WAIT TILL' YOU HEAR IT!!!
-M
Bryson
Re: New THT Build!
#64 Post by Bryson »
Well, the side is on. I decided to stay up and get it on so i can sand tomorrow. The side fit pretty square. Good squeeze out inside. I think it's good. It stresses me out, putting the sides on. The glue is drying, i'm running around trying to suck down sides and nail, it's a production.
I have some soda on top, for weight, but probably not necessary. Makes me feel better. I stood on it when I was nailing down the center, then worked to the outside, hopped down, then clamped and did the outside. Should be plenty sealed and sucked down.
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#65 Post by Bryson »
I stood it up, it's a tall one! I'm working on sanding and rounding the edges tonight. I also need to put in the access panel... more work to do. Good news is, driver is breaking in nicely.
Looking good.
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#66 Post by Bryson »
Well, it rained all night. No progress was made. I was hoping to have this fired up by the weekend... Maybe not.
Now: T18...
Next: ???
Hackomatic
Re: New THT Build!
#67 Post by Hackomatic »
The build quality is superlative. :clap:
Dave H
Bryson
Re: New THT Build!
#68 Post by Bryson »
Did some sanding, came out great! Got all the edges rounded, and some bondo on the imperfections. Round 2 of sanding and bondo this weekend. Maybe i'll be priming on Sunday....
Rounded edges and back in the garage, with bondo...
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#69 Post by Bryson »
Here is a picture of the driver break in station. Looking at about 18 hours now.
Now: T18...
Next: ???
PulseMan
Re: New THT Build!
#70 Post by PulseMan »
Hey Bryson
Looks neat my man :clap:
Thanks for sharing
PulseMan
BUILT
8 T48's 24" 3015LF LOADED
2 WEDGEHORN 10 MKIV's
1 SLA PRO FOR CENTRE FILL
Like us on facebook
https://www.facebook.com/Pulse.Entertainment.SA‎
Bryson
Re: New THT Build!
#71 Post by Bryson »
All bondo'd and sanded down. It's looking good now. I hope to do the access panel tomorrow. Paint probably this week.
Now: T18...
Next: ???
Bryson
Re: New THT Build!
#72 Post by Bryson »
Built the access panel today. Got 2 glued in so far. Looking good. I should be primer'd by the end of the week.
Got them all cut out...
Got them drilled, and T-Nuts in...
Started to glue them in...
Now: T18...
Next: ???
67baja
Re: New THT Build!
#73 Post by 67baja »
Looking very nice. What kind of finish are you going to put on it? Have you been able to hear that bad boy play bass yet?
Bryson
Re: New THT Build!
#74 Post by Bryson »
No bass yet! I'm being patient. Should be done with access panel by tomorrow night. Then I will be ready for primer. That should take a day, then some Duratex. I'll have it in the basement for painting. Should be able to listen at that time. Should be awesome.
Now: T18...
Next: ???
Re: New THT Build!
#75 Post by Bruce Weldy »
Just use some cheap flat black paint. A gallon should be 15 bucks at HD. It dries so fast that you can start putting on a second coat by the time you get through with the first. Then go have lunch and start the duratex. Same thing, start the second coat when you finish the first. You can have all the paint done in a day.
I've done it this way on every build I've done.
