Photos of BF rigs used for live music
wannabe
#46 Post by wannabe »
I've been using carvin for the last 7 yrs and I've never had a problem with them. I have 2 guitars, 1 bass, 3 powered speakers, 2 4x12 cabs, 1 tube amp, a DCM2500, a few raw speakers, DJ mixer, 2 wireless units and so one. I have never had a problem with them at all. The only one that had any problems was the tube amp but that was from 1987 and i beat the hell outta that thing on tour with no road case and it just went down on me this yr. I'd say if you're willing to give em a shot, the DCM power amps are great. I'd easily compare them to more expensive crowns, not the ridiculously high priced crowns, but ones that are 2-400 more. Thats just me though. I know my buddy has a carvin bass, brx 4x10, Redline 1000 head and a wireless unit, and my other buddy have a legacy full stack and 2 powered speakers and there have been 0 problems from the 3 of us with a lot of money invested in carvin equipment.
I understand people have horror stories about them, but I've had them with god knows how many other companies. I won't touch anything Peavey anymore. But if you want to save some money and have a good amp, but the DCM. I've seen em through the damn thing on the parking lot (not in any case) and it turns right back on.
daver
#47 Post by daver »
Bill Fitzmaurice wrote: Personally I'd never own a powered mixer.
I own three! A time and a place for everything. Mostly, I rent them out.
brodave2
#48 Post by brodave2 »
I keep talking to the bands about trying in ears, if it was my band on stage I would probably already have done it, but I provide PA hire for the bands and at the moment they want wedges...and I aint about to fork out for 3 wireless sets of in ears.....
I'm building my BF speakers for a new smaller rig, and I also bought an older 01v for the mixer. I've use it once on a small deal with only 4 inputs used, and I like it so far. I have a yamaha LS9-32 I've been using for a year with my big rig, and that's why I went with a digital for the smaller rig, digital is the only way to go, especially with multi-band gigs, you can save your settings and recall them. As far as the IEM's go, you can get 4 mixes out of two stereo transmitters. Each stereo transmitter will do a mix on each side. The bodypacks have a pan control so the musicians can select either side to hear, or a mix of the two. You can buy as many bodypacks as you want to go with each transmitter. I've worked bands that had their owm EIM setup and they had 4 guys, two transmitters, and 4 bodypacks, 4 mixes.
Tim A
#49 Post by Tim A »
Finally got a half-assed pic of some of the gear. This was a tight space, I couldn't get back far enough to get it all in.
In the pic is a Titan-39 with a DR200 on top, behind the Titan you can see a DR250 on the bassist's rig, and to the lower left is a Wedgehorn.
Nordskov
#50 Post by Nordskov »
And nobody ever found out that all they heard that night were playback to that jukebox :lol:
Way to go!
It looks small enough to be a wedge, not a wedge10, right?!
Nice and compact setup you have.
Tim A
#51 Post by Tim A »
Yes, a small Wedgehorn. We don't typically fold anything back through the monitors if we can help it.
That's my small set up. The other 200 is on a stand, we just used a single sub. In a larger room there'd be an equipment rack and mixer, plus more and/or different cabs.
vlad335
#52 Post by vlad335 »
Thanks for the pic Tim. Yeah thats a tight setup but it seems like you guys did it smart.
How did the bass player like the DR250?
Currently running:
Four Titan 48's, Six Omnitop 12's, Two Wedgehorn 10's, Omni12 2-10
Also Built: Omni15 Tallboy, Omni10.5.
'The hardest material on earth is the human skull'. How do we know this? Try pounding a new idea into one.
Tim A
#53 Post by Tim A »
He liked it, and so did I. Unfortunately it was built as a PA so it's loaded with a full crossfired array, but we were able to tame it with EQ. Not perfect but good enough for a trial run.
#54 Post by Bill Fitzmaurice »
Tim Ard wrote:He liked it, and so did I. Unfortunately it was built as a PA so it's loaded with a full crossfired array, but we were able to tame it with EQ. Not perfect but good enough for a trial run.
The main reason not to use a full array for the backline is the tight vertical dispersion. A half array, three or four tweeters high, makes it easier to hear the highs up close and still gives enough sensitivity for the bass or even keys.
Tim A
#55 Post by Tim A »
Yeah, but it still seemed too bright out front. If I were to build him one, I'd probably give him a switch for all on/half/all off.
#56 Post by Bill Fitzmaurice »
Mostly because the tight pattern meant he couldn't hear the highs going past him. I agree that you don't need the sensitivity of a full array for bass, but the dispersion issue is just as important, assuming the cab isn't up at head height.
DaveK
#57 Post by DaveK »
How would you do the half-on arrangement for better vertical dispersion? Middle 4 tweeters on (assuming 8 tweeter array), middle 4 tweeters off, or every other tweeter on?
#58 Post by Bill Fitzmaurice »
Top half on.
