T30/T48/T60
Marflinger
Re: T30/T48/T60
#46 Post by Marflinger »
Keryn O'Shea wrote: Tue Jan 27, 2026 3:08 pm
Seth wrote: Tue Jan 27, 2026 2:00 pm Three sockets is not a bad option.
4pole lead in, 2pole connectors out
You might even do a better job of lining up the labels :)
Nice one, this is exactly what i thought of yes :)
I assume you had the same thought of better only one cable instead of two.
Did you just two splitter cabs, or every cab the same?
In theory i could do all with three sockets, and on the slaves the 4p input would only get power on 1+-; then cabs are interchangeable again and all have three sockets.
did you think about splitter cable? There are breakout boxes i found, to end a 4p cable in two 2p sockets...even with 8p cables into 4 sep 2p sockets. Probably better boxed then fuzzed with the wiring.
@seth:
Yeah a20 only 1ru; slightly less power, but still banging for sure.
The knockoffs also offer digitals, for example d4-3500...but this would flip my breaker when loading fully. Gives you 4*3600w on 4 ohm in one ru height.
The fp already 2ru height, and by the known bad cooling i'd add 1ru air (rack has enough space) to have the heat covered and shared on two breakers.
And yes overpowered. I could run 8 of the t30 from one unit, so 16 in total, in case i double the cab count.
The cheap amps on the edge of their power have a tendency to die faster, so i'd go for overpowering first.
I'll go with these i think, and take a look how they react when the bass didn't stop for 48 hours^^
DR250 (2 done, 2 to go)
8 T30 (in building phase)
driverack PA+
Wharfedale DP4065F
Prokustik FP14000
Re: T30/T48/T60
#47 Post by Seth »
This is one of the few times I think dual driver cabs, series wired, could make a lot of sense... especially with these high power amplifiers. Four cabs per channel easy. Eliminates the need for creative wiring and jack solutions too.
commander_dan
Re: T30/T48/T60
#48 Post by commander_dan »
Mmmm I can only imagine how hard 8x dual loaded T30s would punch... do it!
6 T30 (24", 3012LF)
2 OT12 (MA, 3012HO)
2 T24 (18", 3010LF)
Running:
DCX2496
XTi 2002
XTi 4002
TRAKTOR Z2
TECHNICS 1210 Mk5's
Marflinger
Re: T30/T48/T60
#49 Post by Marflinger »
Seth wrote: Wed Jan 28, 2026 3:22 pm This is one of the few times I think dual driver cabs, series wired, could make a lot of sense... especially with these high power amplifiers. Four cabs per channel easy. Eliminates the need for creative wiring and jack solutions too.
Well yes, thats the plan.
Just the cable for the big part of the way as 4pole, to avoid having two cables, is to clarify.
(Edit: As i, for the start, want to hook two cabs on one channel; i need 2 channels on each stack of four, so i need the 4P-Cable or two 2P-Cable...)
I think i will just build a breakoutbox with the three sockets, and have all the cabs only with 2 sockets in/out to chain them in parallel.
commander_dan wrote: Wed Jan 28, 2026 9:09 pm Mmmm I can only imagine how hard 8x dual loaded T30s would punch... do it!
I'm on it, just need to finish the DR250s first...and the weather broke down again tonight -.-
I'll open a build thread as soon as i start these. still thinking about the drivers, prv would be interesting. But importing sucks...
Edit:
PRV came to my mind as it is actually cheap af: https://www.gtsusa.net/index.php?main_p ... _id=415862
Or is this scam?
Even including import process it would beat the LaVoce...
driverack PA+
Wharfedale DP4065F
Prokustik FP14000
