Titan 39 20" Wide 12" Sub Build (Completed)
Re: Titan 39 20" Wide 12" Sub Build
Auto bodywork filler.
- Harley
+1Gregory East wrote:Auto bodywork filler.
..and a light sand with 120 grit.
Thanks guys. Next time, I will use BB for the spacer instead of the plywood.
I need a sander (i don't have one at all). What do you recommend?
Titan 39 Build
http://billfitzmaurice.info/forum/viewt ... 30&t=13717
Titan 39 Build #2
http://billfitzmaurice.info/forum/viewt ... 30&t=14458
Titan 39 Build #2
- Dave Non-Zero
if its just for that chip, then a block of wood wrapped in sandpaper! the rest of your build looks great.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
- Harley
If you're building more cabs after this then get a Random Orbital Sander.RENDOG wrote:I need a sander (i don't have one at all). What do you recommend?
Be very careful though. When you take the sander off the work, the disk will spin faster and faster. Resist temptation to place the disk on the work again whilst it's spinning so fast otherwise you'll create hollows lickety split.
Thank you guys.....thanks for the tip Radian.
This is an example of one of the ways I do a cut. I use the ruler as a guide for the circular saw (like a panel jig).
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
How do I fix these panels that are a bit too long? Belt Sander?
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
It looks to me like the angle of the bottom panel of the speaker chamber is wrong. I noticed this when I went to put the braces in and they seemed to be off (too small).
I double checked the measurement of the braces and they were correct. I have a strong feeling I made a mistake somewhere in the speaker chamber assembly.
I'm pretty sure the "tunnels" should gradually get larger from the origin of the speaker. From the picture, you can see that mine go from thin, to wide, and then back to thin again.
I need some advice. Thanks.
By the way, the last panel on the right is not glued in (I placed it there to show the size of the third "tunnel").
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
HAPPY NEW YEARS TO THE BILLFITZMAURICE.COM FORUM FAMILY!!!
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
You must have. It won't bother response all that much, but you'll have to figure out all the brace sizes by dead reckoning.RENDOG wrote: I have a strong feeling I made a mistake somewhere in the speaker chamber assembly.
Will do. Thanks for the help Bill.Bill Fitzmaurice wrote:You must have. It won't bother response all that much, but you'll have to figure out all the brace sizes by dead reckoning.RENDOG wrote: I have a strong feeling I made a mistake somewhere in the speaker chamber assembly.
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
How do I wire the NL4 Neutrik connectors?
I have two of them.
I have two of them.
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
Frederic Gelinas
Re: Titan 39 20" Wide 12" Sub Build (Neutrik wiring question
Parallel: 2 "+" together and 2 "-" together.
Frédéric Gélinas, HF Audio
HFAudio.ca
Free tone Generator
HFAudio.ca
Free tone Generator
The NL4 Neutrik connectors have 4 posts. 1+ and 1- and then 2+ and 2-.
I will be using two Neutrik connectors on one cabinet for the purpose of daisy chaining. The subwoofer is a single coil model 3012lf Eminence.
How do I wire it?
How do I wire it?
Titan 39 Build
Titan 39 Build #2
Titan 39 Build #2
