Titan 39 20" Wide 12" Sub Build (Completed)
Gregory East
Re: Titan 39 20" Wide 12" Sub Build
#46 Post by Gregory East »
Auto bodywork filler.
Harley
#47 Post by Harley »
Gregory East wrote:Auto bodywork filler.
+1
..and a light sand with 120 grit.
RENDOG
#48 Post by RENDOG »
Thanks guys. Next time, I will use BB for the spacer instead of the plywood.
I need a sander (i don't have one at all). What do you recommend?
Dave Non-Zero
#49 Post by Dave Non-Zero »
if its just for that chip, then a block of wood wrapped in sandpaper! the rest of your build looks great.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
#50 Post by Radian »
Harley
#51 Post by Harley »
RENDOG wrote:I need a sander (i don't have one at all). What do you recommend?
If you're building more cabs after this then get a Random Orbital Sander.
Be very careful though. When you take the sander off the work, the disk will spin faster and faster. Resist temptation to place the disk on the work again whilst it's spinning so fast otherwise you'll create hollows lickety split.
RENDOG
#52 Post by RENDOG »
Thank you guys.....thanks for the tip Radian.
This is an example of one of the ways I do a cut. I use the ruler as a guide for the circular saw (like a panel jig).
RENDOG
#53 Post by RENDOG »
How do I fix these panels that are a bit too long? Belt Sander?
RENDOG
#54 Post by RENDOG »
It looks to me like the angle of the bottom panel of the speaker chamber is wrong. I noticed this when I went to put the braces in and they seemed to be off (too small).
I double checked the measurement of the braces and they were correct. I have a strong feeling I made a mistake somewhere in the speaker chamber assembly.
I'm pretty sure the "tunnels" should gradually get larger from the origin of the speaker. From the picture, you can see that mine go from thin, to wide, and then back to thin again.
I need some advice. Thanks.
By the way, the last panel on the right is not glued in (I placed it there to show the size of the third "tunnel").
RENDOG
#55 Post by RENDOG »
HAPPY NEW YEARS TO THE BILLFITZMAURICE.COM FORUM FAMILY!!!
#56 Post by Bill Fitzmaurice »
RENDOG wrote: I have a strong feeling I made a mistake somewhere in the speaker chamber assembly.
You must have. It won't bother response all that much, but you'll have to figure out all the brace sizes by dead reckoning.
RENDOG
#57 Post by RENDOG »
Will do. Thanks for the help Bill.
RENDOG
#58 Post by RENDOG »
How do I wire the NL4 Neutrik connectors?
I have two of them.
Frederic Gelinas
Re: Titan 39 20" Wide 12" Sub Build (Neutrik wiring question
#59 Post by Frederic Gelinas »
Parallel: 2 "+" together and 2 "-" together.
Frédéric Gélinas, HF Audio
Authorized Builder
HFAudio.ca
Free tone Generator
RENDOG
#60 Post by RENDOG »
The NL4 Neutrik connectors have 4 posts. 1+ and 1- and then 2+ and 2-.
I will be using two Neutrik connectors on one cabinet for the purpose of daisy chaining. The subwoofer is a single coil model 3012lf Eminence.
How do I wire it?
