Titan 39 20" Wide 12" Sub Build (Completed)
RENDOG
#1 Post by RENDOG »
I'm starting my first build tomorrow and somewhat decided on the width of the box (20"). I purchased and received the kit from Speakerhardware.com a few days ago and was very happy with the results.
I'm still missing a jigsaw and haven't really decided on one but I can make the initial cuts without one so i'm not too concerned.
User, doncolga, helped me out by giving me some really good advice so i definitely want to point that out and say thank you once again.
Here are some pics of the materials and tools in the garage.
Frederic Gelinas
Re: Titan 39 20" Wide 12" Sub Build
#2 Post by Frederic Gelinas »
Have fun making saw dust!
Those clamps will break. I once bought 4 of these and they all broke within a month. I'll never buy plastic clamps again, at any price.
Frédéric Gélinas, HF Audio
HFAudio.ca
Free tone Generator
RENDOG
#3 Post by RENDOG »
Thanks. I saved the receipt lol.
SeisTres
#4 Post by SeisTres »
fgelinas wrote:Have fun making saw dust!
I too bought those and broke three the first week. After that, I went out bought the metal ones. However, after learning how to use clamps, I had about 3 left I haven't broken one of them. Just go easy on the pressure they get the job done.
RENDOG
#5 Post by RENDOG »
Thanks.
Going to make first cuts right now.
RENDOG
#6 Post by RENDOG »
Just completed a homemade jig. I technically need to wait for the glue to dry before using it.
I had fun with the clamps.
RENDOG
#7 Post by RENDOG »
If I want the enclosure to be 20" wide, do I make the inner panels 19" wide or 19.5" wide?
Harley
#8 Post by Harley »
RENDOG wrote:If I want the enclosure to be 20" wide, do I make the inner panels 19" wide or 19.5" wide?
What do you mean by 'enclosure'?
Frederic Gelinas
#9 Post by Frederic Gelinas »
Total width = panels width + 2x sides thickness. If you are using 1/2 material, 19" + 2x 1/2 will give you a 20" total width.
HFAudio.ca
Free tone Generator
RENDOG
#10 Post by RENDOG »
The speaker box or cabinet....the entire full thing.
RENDOG
#11 Post by RENDOG »
Thank you very much...I cut the sides and the back panels.
subharmonic
#12 Post by subharmonic »
glue the pads on those clamps. I almost forgot one dropped off in one of my builds, it would have sucked rolling it out of a Tuba 60. Keep an eye out for Irwin clamp sales, I like the orangy cheapos like that since you can reverse them and make them expanders too, I have found that useful many times.
I build my Titans same width, wish I would have done 12" drivers so good call. They are light and easy to move. Make sure you read the plans through completely and then read a couple steps a head of your daily build.
I need more bass
CW Mcall
RENDOG
#13 Post by RENDOG »
Thanks Subharmonic, good info.
I cut the top today. Did a plunge cut and messed up with jig. Then realized I definitely needed a jig saw. I was tempted to buy that Dremel Trio thing that cuts, sands, and routes but I ended up purchasing a $70 Ryobi jigsaw at Home Depot (with a laser).
The garage is full of sawdust (which smells very good by the way). I'm really enjoying this build. The Baltic Birch is beautiful, I paid $34 or $37 for a 5x5 sheet. I purchased 2 sheets from a local lumber yard.
I have a folding table and one pair of saw horses but some Walmart containers came in very handy.
RENDOG
#14 Post by RENDOG »
I cut both side panels and the top panel (#1). I cut panel #2 to 14" like it says to do in the beginning (rough measurement). I drew the measurements from the sketchup on the side panel as instructed. I installed panel #1 which is the top.
When I went to place panel#2 in place, I noticed that it was longer than it should be. I checked the page and it says panel 2 should be 13 3/8" with angle cuts of 3 degrees and 18 degrees.
Do I need to cut the panel again? Will I have to do this to all panels?
#15 Post by Tom Smit »
My understanding is that the bigger numbers are for when one pre-cuts all the panels. The correct size for each individual panel will be in the plans. I don't know about the numbers on sketch-up since I use the plans solely. I have used sketch-up to get a visual of what-is-what.
P.S.-rather than getting the Dremel tool, you should get a regular router if you're going get one. The Dremel is to light-duty.
