Bill Fitzmaurice wrote: ↑Sat Jul 23, 2022 3:05 pm
Their data is flawed, because modeling programs are only accurate up to about 200Hz. They also show results if mounted in a wall baffle, not enclosures of equal size. Worse, they measure one at 2.83v, one at 4.0 v. I don't know what that's all about, but it accounts for a 3dB difference.
Thanks again Bill.
I'll probably start the saw tomorrow.
Dang Jens, you're moving right along on this venture
I'm not sure the dome size will or won't negatively effect the sonic quality of your build. But, I would think if the frame size is still 2½" or less, you should be fine. We'll see what Bill has to say about the suitability of 1" tweeters instead of the recommended 3/8 to 1/2 inch variant. I'm curious too.
1" tweeters won't have as wide dispersion as smaller units. The reason to use 1" is when they're crossed over fairly low, which you do with larger midbasses because they have narrower dispersion in their upper end than smaller midbasses. Other than with subs the reason to use a particular size driver is output capability versus dispersion, which is always a compromise.
Read the instructions. Twice. And then one more time.
Then check the drivers you're buying. Then check them again.
I'll probably be better at cutting them as I go along. First one is not pretty. I'll smooth it out with some acrylic filler. Wood filler, perhaps?
Sorry guys. I won't be finishing the project anyway. Thanks for all your answers.
I'll say goodbye (again!) - and hopefully this time, I'll be able to stay off the internet and speaker addiction for good.
I actually just took a drill trough all "DIY" components I have lying around. Not the ones I'm actually using ofcourse.. It's really not healthy for me - time to focus on the family
