HT setup using T24
T_Gowan
Re: HT setup using T24
#16 Post by T_Gowan »
Yes I have been through this menu. The only speaker that can have cross over adjusted are the main center and surround. The sub only level and distance
IN PROGRESS Jack 10 Lite x2, hopefully 4
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
T_Gowan
#17 Post by T_Gowan »
Who has experience with the mini dsp. I see a main board, a input output connector board and an optional interface board to allow more controls via PC . What is the least I need to just do hi and low pass
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
#18 Post by Bill Fitzmaurice »
You can't use it with your receiver to high pass. That would require the ability to insert it between the pre-amps and power amps.
T_Gowan
#19 Post by T_Gowan »
I am using an external amp for the sub. The LRC and surround is being processed by the Sony. I just need to process the sub
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
You said 'The only speaker that can have cross over adjusted are the main center and surround', with no mention of the L/R. Whatever. For both low passing and EQ I'd use this:
https://www.parts-express.com/Dayton-Au ... er-230-520
It's not user friendly, because the instructions are crap. But I found other subs that use the same control app and their instructions are OK.
#21 Post by Seth »
Punctuation to the rescue!
T_Gowan wrote: Sat Jul 16, 2022 3:27 pm Yes, I have been through this menu. The only speakers that can have cross over adjusted are the main, center, and surround...
LOL
#22 Post by Bill Fitzmaurice »
Punctuation matters.
jimbo7
#23 Post by jimbo7 »
Let's eat kids!
Let's eat, kids!
T_Gowan
#24 Post by T_Gowan »
For an old guy I'm falling into bad habits.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
T_Gowan
#25 Post by T_Gowan »
Order the Parts Express Dayton Audio device, A little more than I hoped to spend but it should do the trick. 150 Canadian with tax and shipping. The shipping was as much as the unit.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
T_Gowan
#26 Post by T_Gowan »
Got the unit and the learning curve is a bit steep due to crappy instructions. But it does the trick.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
T_Gowan
#27 Post by T_Gowan »
Works well with iPad but android phone won't seem to connect.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
T_Gowan
#28 Post by T_Gowan »
https://hometheaterhifi.com/reviews/aud ... ontroller/
This review and instructions are quite good compared to the instructions with the unit.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
#29 Post by Bill Fitzmaurice »
I ended up using the instructions for the Earthquake Sound MiniMe DSP, which uses the same software.
